the turtle turtles trubo build lol
22.35 is technically what it can read, but fueling issues hit above 17psi, I think...
https://www.cobaltss.net/forums/show...highlight=3bar
Good read!
Good read!
Last edited by Edubs; Dec 10, 2009 at 10:56 AM. Reason: Found Link w/ Good Info...
Good read!
Good read!
most of the boosted 2.2 and 2.4 ecotecs are only using their stock 1 bar sensor... the only REAL advantage it would give you is to have some part throttle boost tuning however our ecms dont really have the functions in there for that so it doesnt really help
well i had a biit of a set back today.. i broke one of my piston rings so now i have to order a new set.. take three days so everything will be on hold
Last edited by *S!CC_R@c!NG_TURTL3*; Dec 10, 2009 at 06:14 PM. Reason: Automerged Doublepost
so i can use my stock map sensor to run the progessive controller for meth ?
oh and i got my injector harness from ottp today
if your running a regular one then it could be switched on above 110kpa (ie when you go into PE)
sorry guys havent updated in awhile my kids been sick and havent had much time to stay late at the shop to work on my motor... i will put some updates up tonight after work.. still awaiting turbo kit
i thinkin ima just run a regular set up and sell the progressive controller.. dont have much money let to play with lol
alright guys i know its a lil over do... here u go
the pistonsd and rods together.. the clips were a pain in the ass !!
the piston ring compressor
all pistons in
http://s942.photobucket.com/albums/a...t=MOV00918.flv
vid of the motor and pistons
all pistons in
Last edited by *S!CC_R@c!NG_TURTL3*; Dec 15, 2009 at 07:24 PM. Reason: Automerged Doublepost
thnx man.. i just woke up one morning and was like, ima paint my block red !
... but the motor should dun today... i did the balance shaft timing ( super easy) and installed the water pump.. i just need to slap the head on and do the timing
alright guys i got bad news today... well a frew things actually... first off i called canda post because i still havent recieved my turbo kit.. come to find it was shipped out to california instead of fl.. so i wont recieve it until dec 26. second thing is i went to do my time today and one of my cam gears are broken so now i have to order a new one
so here what im going to do... since i no longer have money to get tuned. im gunna order my cam gear tomorrow finish the timing. hopefully slap the motor and tranny together on sat and drop the motor back in my car. then ill break the motor in until i get paid again and then by that time i should have the turbo and ill slap the kit on and get tuned. so thats pretty much the game plan now
idk bro it seem pretty straight forward just have the crankshaft sprocket at 5 oclock and align the colored links up
yea they fucked up not u.. i double checked the adress and its correct
Last edited by *S!CC_R@c!NG_TURTL3*; Dec 17, 2009 at 04:38 PM. Reason: Automerged Doublepost
polished valve cover
