Forced Induction Turbos/Superchargers
wastegate and bov vacuum problem
Old Aug 22, 2012 | 12:43 PM
rcarr0327's Avatar
okay, so today i was under my hood trying to work on this homemade catch can. i heard a vacuum leak and started searching. i put my finger over the atmosphere port on my wastegate and it started sucking. when i close the vacuum i noticed that my BOV opened up and when i took it off and created a leak the BOV closed again, not how its supposed to be.
so i took a metal T connector that i got from ZZP with my kit and replaced it with the plastic one i had in there. the vacuum noise decreased and the bov does stay open when idling now.
i have the vaccum line from my intake manifold to this metal T, then one side goes to my wastegate and the other to my bov and boost gauge.
should the wastegate be doing this? how do i fix it. here is a video to understand better
Wastegate and bov problem - YouTube
Old Aug 22, 2012 | 01:41 PM
07cobaltguy's Avatar
maybe the diaphragm in the wastegate is torn?
Old Aug 22, 2012 | 10:29 PM
rcarr0327's Avatar
how would i check this out? thanks
Old Aug 23, 2012 | 01:15 PM
Have you ever taken the wastegate apart to change the spring? There is a orange diaphragm in there if its damaged it could cause a leak.
Old Aug 23, 2012 | 01:23 PM
rcarr0327's Avatar
would the wastegate not hold boost if it was broken? because its holding the 8psi perfectly
Old Aug 23, 2012 | 02:13 PM
thats true it probably would spike higher boost i would think if there was a leak.
turbochargedss2012
Sep 20, 2023 12:17 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
