08 cobalt changes
Old May 31, 2007 | 07:56 PM
  #201
Psykostevo's Avatar
Originally Posted by redSSBalt
The 2.4 for next year not only lost the SS badging, but it also lost rear wheel disc breaks as well!! I was talking with the neighbors son yesterday, he's a chevy mechanic for the past 22 years. That's what he told me!! He definetly did tell me that buying the 2.4SS was a smarter move than buying the 2.0 S/C if you want to mod the motor. He said the 2.4 has a better bottom end for the turbo's!! It will hold up a lot better than the 2.0!!
He's full of it. The 2.4L only handles about 8-10psi, the 2.0L holds 20+psi. I don't see how the 2.4L has better ability to handle boost.
Old May 31, 2007 | 08:17 PM
  #202
redSSBalt's Avatar
Originally Posted by LandonElf
I definately understand having a mechanic you can trust in, there even more useful than having a lawyer has a friend. They can really get your behind out of a bind.
However
Though the 2.4 n/a ecotec is a GREAT engine, if he told you that it was "a better choice" in regards to strength or performance, then he is dead wrong man. If he said "more economical" or "more efficient" or "more responsible" then yea i can understand that. But if he meant "more performance" then that is just wrong.
The 2.0 was built to be the top performing cobalt engine, so saying that the 2.4 is "stronger" is kinda retarded. Especially considering that the 2.0 has a forged crank, forged rods, sodium filled exhaust valves, etc etc etc
Don't get me wrong, the 2.4 is a great car and i'm not bashing on it. But if you wanted the strongest and best performing engine that you could get in a cobalt, then you bought the wrong car my friend.
I would have to tend to disagree with you on this due to the fact that there are many threads on this forum talking about blowing up the 2.0 and misc other problems that people are having with it!!
Old May 31, 2007 | 08:24 PM
  #203
PolishPauL's Avatar
That would be because we run a lot more boost with the 2.0 and how many boosted 2.4s are there?
Old May 31, 2007 | 08:32 PM
  #204
redSSBalt's Avatar
That's the exact point that the mechanic is making!! The 2.0 can't HOLD the Boost!!!
Old May 31, 2007 | 09:19 PM
  #205
avro206's Avatar
each einge has advatages and disadvatages.
If you coud build a 2.4L with all forged internals and get a turbo working correctly---it would eat any 2.0. However, this is all theory cause no one has done it.
As it sits factory VS factory the 2.0 is obviously better (except for no VVT)
Old May 31, 2007 | 10:11 PM
  #206
LandonElf's Avatar
Exactly. We arent talking about which has the most potential. Because potential is just a matter of how much money you have. I've seen Geo storms that would kill anything on this site!!
The argument is which of the two engines is the best performer from the factory. And any person who knows anything about cobalts knows that its the 2.0
Old May 31, 2007 | 10:15 PM
  #207
Psykostevo's Avatar
VVT blows!
The reason the 2.0L keep blowing has nothing to do with the motor's internals. It has to do with fuel problems in the 4th cylinder. The cylinders could handle it if they didn't lean out so much.
20psi is still greater than 10psi. We have trouble handling 21+psi, the 2.4L could never handle that. Besides the Compression in the 2.4L is not optimal for boost either.
Old Jun 1, 2007 | 12:28 PM
  #208
redSSBalt's Avatar
I was talking about potential actually, sorry if it came across any different. Plus remember that there's no replacement for displacement!
Old Jun 1, 2007 | 12:48 PM
  #209
N8s07SS's Avatar
I think LandonElf was talking about bolt-ons, not replacing internals. Does anyone know what engine the drag Cobalts use? Wouldn't that be a good hint at which engine can hold the most power?
Old Jun 1, 2007 | 12:54 PM
  #210
redSSBalt's Avatar
They use the 2.2. I was talking about between the 2.0 and the 2.4 though.
Old Jun 1, 2007 | 05:35 PM
  #211
thought's Avatar
On another note, don't trust any info you hear from people at the dealership regarding this. Heck, dropped by today, and the salesmen there didn't know there was an SS above the 2.4L, lol.....
Old Jun 1, 2007 | 06:53 PM
  #212
LandonElf's Avatar
Originally Posted by TheMaker
every thread, almost every post
I bet I could get a turbo to run 21psi on a stock 2.4l and not break a single thing. You sound like blackSSNA last night in the chat room.
A few points
1) I'm willing to take that bet. Now go buy a Cobalt SS/NA, a turbo and all the components, an intercooler, and hp tuners.
2) My car hit well over 21psi for about 8 months due to a disconnected actuator and didn't have a single problem besides the owner (me) worrying all the time.
3) The 2.4 is a capable engine, but the 2.0 is specifically built for boost. period
4) Boost is not the same from all power adders. 20 psi from a turbo is different on an engine than 20 psi from a blower. To compare apples to apples, you would have to put a blower on the 2.4 and push 20 psi. Then compare its reliability to a 2.0 with a pulley.
Man i need to get away from these forums, there really eating in to my tv watching time.
Old Jun 1, 2007 | 07:52 PM
  #213
Brandon97Z's Avatar
Only 8-10? Check out this link http://www.solsticeforum.com/forum/s...ad.php?t=31971
390whp stock internals. They ran 315whp w/ 13-15 psi, so the 390 is close to 20lbs.
Old Jun 1, 2007 | 08:01 PM
  #214
Psykostevo's Avatar
That 390whp was calcuated from using the 1/4 times and trap speed, not exact science. My car supposedly puts down 325whp when you calculate it that way!
You are looking at Bill Hahn's car, not an average owners. And the 2.4L solstice motor is different than the 2.4L Cobalt motor in a few ways.
You can run OVER 20 psi on the LSJ if you want to, but it won't last long, just like 20psi on the 2.4L won't last long, and most likely is not on pump gas that most people would drive on.
I think you may have meant originally that the 2.4L will make more HP per PSI than the LSJ. In that case you are correct, and cannot argue that. The larger displacement, and higher compression will make significantly more HP than the LSJ motor.
Driving to work on a 20psi LSJ (with proper tuning) you can do all the time. Driving to work on a 20psi 2.4L (with proper tuning), you might want to buy a bus pass.
Old Jun 2, 2007 | 01:24 PM
  #215
Brandon97Z's Avatar
The motors are different? Care to explain what those differences are cause thats news to me. It doesn't matter who's car it is, its pussing almost 400whp on a stock internaled 2.4 which is more then 8-10psi you stated. Just showing the 2.4 is a pretty stout motor especially being NA from the factory.
Old Jun 2, 2007 | 07:55 PM
  #216
redSSBalt's Avatar
I am glad to see some others stepping up to stick up for the 2.4 motor!!
Old Jun 3, 2007 | 08:34 AM
  #217
Frank2029's Avatar
why does anyone care? if you put in a decent chunk of change into a decent car. there is endless possibilities.
Old Jun 3, 2007 | 07:43 PM
  #218
LandonElf's Avatar
Exactly.
Plus the 2.4 in the solstices is RWD in addition to all of the other tweaks and changes. So its not a good representative for 2.4 Cobalts by any means.
Old Jun 3, 2007 | 07:52 PM
  #219
RollOver360's Avatar
O man no more ss/sc... that sucks. I have had mine for 2 months and put 8,000 miles on it... better go park this one and find a beater..
later
Old Jun 3, 2007 | 10:16 PM
  #220
Brandon97Z's Avatar
Exactly.
Do you know what those tweaks are?? People keep saying the motors are different somehow but they never say what those differences are, hrmm funny. And the fact thats its rwd is irelevant the strength of the motor is what i'm talking about.
Old Jun 3, 2007 | 10:28 PM
  #221
Psykostevo's Avatar
They have many differences. But if you want to convince yourself that you can put 400hp on the stock internals, I'm not STOPPING you from doing whatever you want. If you want to drive you Cobalt everyday, you should probably listen to the 8-10psi I recommended. You can push a little more if you really know what you are doing.
Old Jun 3, 2007 | 11:07 PM
  #222
Brandon97Z's Avatar
Tell me what the differences are then!!! Don't just sit here and tell me "they are different" PROVE IT. Now i didn't come one here to say the 2.4 is better then the LSJ or anyother motor. I just wanted to show what the 2.4's are capable of. I'm not talking about what only the normal joe blow can achieve, but rather showing what can be achieved when you do things right and really push the stock 2.4. And theirs no need to convince myself to put 400 on stock internals as i've shown you that it can and has been done.
Direct injection for one for sure. pistons, rods, crank, head, probably.
Your thinking of the LNF 2.0 DI turbo motor. I'm talking about the differences between the solstice 2.4 and cobalt 2.4.
Old Jun 4, 2007 | 04:52 PM
  #223
MikeyMo84's Avatar
http://www.autoblog.com/2007/06/04/c...rged-for-2008/
Chevy cancels Cobalt SS Supercharged for 2008
Posted Jun 4th 2007 3:35PM by Frank Filipponio
Filed under: Car Buying, Coupes, Sports/GTs, Chevrolet
It's been a little while since we talked about the Cobalt SS Supercharged and maybe that's part of the problem. Although this sporty version of the econo-minded Cobalt and one step up from the non-blown Cobalt SS has won its share of accolades from sporting organizations and publications, it hasn't seemed to keep up with the vehicles at the head of the sporty compact class. We know that it is a competent performer, but it seems that GM has quietly decided to discontinue it. The naturally aspirated SS, however, will soldier on, but with a new name. For 2008, the Cobalt SS becomes the Cobalt Sport, and the Cobalt SS Supercharged is being dropped altogether. It could be that Chevy wants to focus more attention on the upcoming HHR SS we showed you a little while ago. Whatever the reasoning, it appears the little Cobalt that could, will be no more. Unless, of course, Chevy is just working on finding a way to get the GXP/Redline 260-hp mill into the Cobalt's engine bay. Follow the jump for the full list of changes for the 2008 Cobalt.
Thanks for the tip, Chris!
[Source: GM]
Deletions
(21U) Laser Blue Metallic exterior color
(56U) Sunburst Orange Metallic exterior color
LTZ Sedan model
SS Supercharged Coupe model
New Features
(37U) Imperial Blue Metallic exterior color
(39U) Blue Flash Metallic exterior color
(87U) Slate Metallic exterior color
(JL4) StabiliTrak stability control system
(NW9) Traction control
(ASD) Head-curtain side-impact air bag delete for Fleet and Government order types
(UE0) OnStar delete for Fleet and Government order types
Changes
1AM37 is now called Sport Coupe and the equipment group code is now 1SP
1AM69 is now called Sport Sedan and the equipment group code is now 1SP
(TV5) Sport Package is now called Performance Appearance Package and is an available option on 2LT Coupe and 2LT Sedan. The 3LT Coupe and 3LT Sedan equipment groups are deleted.
(ASF) Head-curtain side-impact air bags are now standard on all models
(US8) AM/FM stereo with CD player and MP3 playback is now standard on all models
(U2K) XM Satellite Radio is now standard on all models
Instrument panel uppers are now Ebony on all models
LT Sedan with neutral interior now has woodgrain trim
*prays to the GM gods*
Old Jun 4, 2007 | 05:49 PM
  #224
Brandon97Z's Avatar
oh damn, yeah my bad. Thanks for correcting me in a civil manner. I bet the crank is different, though.
Nope same crank, that wouldn't explain the reason it can handle more hp anyways since most eco's don't need the crank worked on until the 600hp mark i believe.
Old Jun 5, 2007 | 02:20 PM
  #225
Brandon97Z's Avatar
I love how people make statements about stuff that they have no knowledge of and then can't back it up.
dennis69
Oct 20, 2015 04:49 PM
Rayray2781@gmail.com
Sep 20, 2015 01:52 PM
Bluelightning
Sep 8, 2015 05:18 PM
jthwjde
Sep 7, 2015 09:24 AM
