200,000 mile cobalt....
Old Sep 7, 2010 | 10:46 PM
  #451
miked5426's Avatar
it's my personal opinion that i have a severely stretched timing chain. Lot of jerking wen i get on or off accellerator.
Old Sep 8, 2010 | 12:40 AM
  #452
scottie's Avatar
Maybe it has to do with the water that got into your engine the other day?
Have you ever replaced the chain?
Old Sep 8, 2010 | 04:02 AM
  #453
miked5426's Avatar
No, its been this way for at least a year...gradually getting worse. Chain hasnt been replaced and i dont intend to. With 204,000+ miles, theres alot that would have to b done once the hatch is opened. Id rather leave her alone untill it blows or becomes impossible to drive...
Old Sep 8, 2010 | 11:53 AM
  #454
YoBaltSS's Avatar
Originally Posted by 08SSTCRD
All those things are considered normal for a DSM.
Ecotecs should easily go 200K-300K miles without overhaul.
That's what i've heard. DSM engines have always been known as being strong, but extremely high maintenance. Add in that the car was nearly 15 years old and there ya go. Even low-end cars are simply more reliable now a days.
Old Sep 9, 2010 | 11:28 AM
  #455
miked5426's Avatar
205,000
Old Sep 10, 2010 | 09:26 AM
  #456
NickD's Avatar
"It's not the years, honey, it's the mileage"
Perhaps you'll go the route of that guy with the Volvo a number of years back. He hit 1 million miles and Volvo took his old car and gave him a brand new one free.
Old Sep 10, 2010 | 11:01 AM
  #457
padlock's Avatar
^^ that would be awesome!!
Old Sep 10, 2010 | 11:12 AM
  #458
2FST4U's Avatar
Volvo, Honda, Gm, and Ford have all done that. They find a record Mile vehicle then they give you a new one take your old and stick in a Musuem.
Old Sep 10, 2010 | 11:18 AM
  #459
Kahless's Avatar
Originally Posted by miked5426
FYI, guys i ran outta gas for first time ever today. forgot i was low on fuel..ran out about 1/16th mile from the gas station LOL.
i almost did that crossing the 20 mile bridge between lafayette and baton rouge in louisiana. low fuel light came on in before lafayette and i figured i would get outta town before i changed. then the bridge started. i pulled into the gas station at 432 miles on that tank. dunno how much i had left cause i wanted to get outta there so i put in 30 and went on my way. i wish i had filled it up to see how close to pushing my car i was. i'm at 147,300 now. or something along those lines.
Old Sep 10, 2010 | 02:50 PM
  #460
miked5426's Avatar
How do u get so many miles to a tank? i can get 350 at best. most of the time, i get 320-330
Old Sep 10, 2010 | 02:56 PM
  #461
CrystalRedSS's Avatar
most likely he doesnt have an ss. thats why he gets so many miles per tank.
Old Sep 10, 2010 | 03:15 PM
  #462
b00sted06ss's Avatar
how many miles are you at now?
Old Sep 10, 2010 | 03:20 PM
  #463
Kahless's Avatar
bingo. and i put 13 gallons in it before i left. over the trip there i made it 704 miles in 10:17 which was ok considering the monsoon i drove through in east texas/west lousiana and conroe being 30mph with stoplights every 200ft. the way back took 13 or so cause 10 turned into a parking lot in mississippi and i hit a broken driveshaft on the bridge coming out of baton rouge slashing my tire, so had to stop in lafayette for 2 hours to get a new tire. ive hit 450 on a tank before when i was hypermiling and still had a bit left. i was averaging 42mpg for about 2 months and got really sick of driving that way.
Old Sep 10, 2010 | 04:44 PM
  #464
miked5426's Avatar
I try to hypermile sumtime, but i gotta let my SC work too.
205,400
Old Sep 10, 2010 | 06:17 PM
  #465
myfakeevo's Avatar
so instead of replacing a 20 dollar part you would rather blow your motor?
why bother changing the oil or tires too.
Old Sep 10, 2010 | 07:18 PM
  #466
miked5426's Avatar
$20 part? There alot more to it. If im gona disect my engine at 200+ k miles, then it would stupid to not replace alota uther stuff n there. That $20 will turn into $2000 easy after labor. I dnt have money for that and YES...Iam gomna run her till she dies...
Old Sep 10, 2010 | 09:31 PM
  #467
Render2009's Avatar
i think that his car is going to be fine.. i mean look hes gone this far why cant he go farther?
Old Sep 10, 2010 | 10:29 PM
  #468
Shanedude's Avatar
Labour for a timing chain is quite a bit of cashola.
Old Sep 11, 2010 | 04:02 AM
  #469
miked5426's Avatar
plus im sure id have to do a timing tensioner? and if im getting inside all that i might as well do a head gasket, which means head bolts too? so it all adds up. lots and lots of money i dont have. So, id just assume leave it be untill its hard to drive. for the most part, the car drives and accelerates pretty smoothely
Old Sep 11, 2010 | 10:12 PM
  #470
myfakeevo's Avatar
you obviously have zero knowledge about motors. so ill just leave it at that and wont bother posting in here again.
Old Sep 11, 2010 | 11:24 PM
  #471
rukkee's Avatar
GM redesigned the timing chain tensioner sometime around mid 2006 . If i were you i would buy the new one and see if it fixes the issue . You really don't have to get too far into the motor to do it ..... some people don't even remove the valve cover.... they just unscrew it and screw the new one in ....( I would do it the right way IE removing the valve cover to activate the new tensioner ) . The old style tensioners are known to collapse so it could be what your seeing.
Old Sep 11, 2010 | 11:27 PM
  #472
Render2009's Avatar
Should i be worried about a tensioner then i mean my car is an 06.. but i only have 20k miles.
Old Sep 12, 2010 | 01:16 AM
  #473
JL-KA's Avatar
My 08 had a tensioner fail.
Old Sep 12, 2010 | 01:19 AM
  #474
JL-KA's Avatar
It's not about the mileage. It's the design. I'll put it this way...when mine gave out, the car jumped timing(multiple teeth) and pistons hit valves, next thing you know the dealer is replacing most of the top end. They did it under warranty but not without a fight.
Old Sep 12, 2010 | 01:46 AM
  #475
miked5426's Avatar
Im sorry, but i dont feel that much of an issue. Wen i accelerste, there is no knocking or timing issues. Its as smooth as can be just about. I do not know bout cars or motors so replacing the tensioner wouldbt b sumthing id wanna mess with...
