Accessory Switch
The radio should turn on when swiched to accessory ,which option do you want.
1)Powered all the time (brake light switch power wire 10 amp fuse)
2)Powered when the key is in the ignition ( interior lights
3)Powered when the key is tuned to accessory(This is how it is already and most accessories in the car)
4)powered in the run mode
I think the Stock radio is remotely turned off when the power saver mode comes on.And this is only is bypassed by being in the run mode because it will run with ign off for a while with the key out and the door shut.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
09BlkCrusader
Sep 9, 2015 04:47 PM
