Accessory Switch
Old Jan 10, 2009 | 12:15 AM
Red Devil 07's Avatar
Accessory Switch
Does anyone know which fuse turns on when switched to accessory? i wanna turn my stereo on without havin to turn to the start position.
Old Jan 10, 2009 | 03:36 AM
Xavipheus's Avatar
Sunroof fuse should do the trick. You'll need a mini fuse tap to do it. The fuse is located right under the dash in the passenger foot well.
Old Jan 10, 2009 | 03:52 AM
jefferyss's Avatar
well what did you wire the stereo to in the first place? does it not come on only when the car is switched to accesory or is running?
Old Jan 10, 2009 | 08:15 AM
Coblasts's Avatar
The radio should turn on when swiched to accessory ,which option do you want.
1)Powered all the time (brake light switch power wire 10 amp fuse)
2)Powered when the key is in the ignition ( interior lights
3)Powered when the key is tuned to accessory(This is how it is already and most accessories in the car)
4)powered in the run mode
I think the Stock radio is remotely turned off when the power saver mode comes on.And this is only is bypassed by being in the run mode because it will run with ign off for a while with the key out and the door shut.
Old Jan 10, 2009 | 09:57 AM
i want it powered in accessory it doesnt have the red wire u have to tap that to a fuse stock harness never had it.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Cobalt08LS
Jun 19, 2016 07:29 PM
grampss
Sep 27, 2015 08:51 PM
TylerJHowell
Sep 21, 2015 06:47 PM
09BlkCrusader
Sep 9, 2015 04:47 PM
