Back Seat remove?
Originally Posted by mafsu
to take the bottom out just push it towards the back(there's a clip on each side) when it clears the clip pull up. For the backs I'm pretty sure you'll have to unscrew it at the hinges.
you arent taking it out to put a system in are you?
becuase i tried it, and its the same size
I'm swapping seats with another guy in a few days. The front seats are only held in with 2 bolts each. I've had back seats out on other cars just by pushin down and in then lifting out. These seemed awful tight. I was working outside and it started to rain so I stopped. I'll try again tomorrow.
i am trying to remove my back seats now in my car so i cant start prepping them to two tone paint. So alls i need to do is push down and in at the front and then pull up and the bottom part should come out. I want to try this when i get home from work.
thanks
thanks
I have dialup, enlighten me, I have had the bottoms out more than a few times but I couldnt get the back out, It appeared to be held with the 2 main bolts in the trunk floor and I couldnt see what was holding it in the sides.
hard to explain.
but looking at the back seat, on the bottom left and bottom right corners there are locking pins.
you will have to pull back the corners a little to see it,
and youll need a screwdriver to jam in there and allow the pin to come out.
get in there and play around and youll soon figure it out
importkiller
Sep 30, 2015 07:18 PM
