Bleeding f40 trans
Old Jun 28, 2019 | 07:52 PM
LnfMikey's Avatar
Bleeding f40 trans
I have been here alot asking alot of questions hopefully this is my last question, does anyone know how to bleed the f40 transmission. I tried the pump in the brake fluid reservoir but i dont know if im doing it right and the clutch pedal still stays on the floor when pressed in. Anyone know how to properly bleed it and should i bleed brakes or clutch first? Thanks!
Old Jul 1, 2019 | 08:03 PM
I'm going to assume it's not significantly different than the F35. Get fluid to the bleeder and the close it and pull vacuum on the brake reservoir for 10mins. Release vacuum and slowly pump clutch two or three times. Then repeat the vacuum and slow pump until the pedal starts to feel better.
Old Jul 1, 2019 | 08:04 PM
Also might want to change the thread title to bleeding clutch for F40 transmission.
Old Jul 1, 2019 | 08:33 PM
I did it the same way as a f35 worked fine for me
codyss
Apr 20, 2019 11:06 PM
Snail_SS
13
Jan 6, 2019 09:04 AM
ctg5040
May 8, 2012 09:54 PM
Black_Turbo_SS
Apr 11, 2010 07:04 PM
05RLS2
Dec 21, 2009 10:56 PM
