Boost fluctuation or surging
My car: 2005 Cobalt SS/SC
My mods:
- 3" Fujita cold air intake w/ AEM dryflow filter
- 3"/2.5" Downpipe w/ highflow cat
Misc:
- Operating temps have stayed below 200 consistently, no excessive heat has been observed.
- My average fuel economy is between 30-32mpg mixed driving
- The spark plugs show even and normal wear
- No codes of any type are currently being thrown and all connections have been checked as I recently detailed the car.
The problem:
While driving I notice my car will experience a fluctuation in boost around when it reaches 7psi it will surge to 10-12 psi then drop back down to 8-9 during acceleration. When I near redline the boost will sometimes fluctuate between 12 and 14psi. The boost will do this at varying cruising speeds as well but i observe it most under the said conditions. I have only noticed this after I installed the performance downpipe. I don't fully understand how the addition of a higher flowing exhaust component would cause the boost to fluctuate in this manner. Has anyone else experienced this problem? My initial thoughts are maybe some type of leak in the hoses, or an ecu hiccup. I would love to hear any useful suggestions based on the information I have provided.
My mods:
Misc:
The problem:
Do you feel the car surging as well, or is it just seeing the guage move? Also, if the car is totally stock minus the intake and downpipe I believe the ECU will limit boost to 12.5. Do you have an aftermarket exhaust or just the downpipe? It almost sounds like this could be a cat problem.
The rpms dont really have time to move, it happens really quick so there isnt enough time for the car to surge forward. The exhaust is completely stock and so is the manifold. The only thing I have modified is the downpipe.
I paid attention to the problem tonight, The rpms were non responsive to the boost gauge. I also tested the clutch and its not slipping. Any, other ideas folks? How would i be able to tell if it was a cat problem?
Actually don't you get a decrease in boost from swapping exhaust components particularly header/downpipe?
Last edited by theneelster; Aug 22, 2008 at 11:09 PM. Reason: Automerged Doublepost
Sl0wbaltSS
Nov 21, 2018 11:11 PM
