Boost Gauge question???????????
Old Jun 30, 2009 | 07:12 PM
hawkeyez's Avatar
How hard is it to swap the stock boost gauge with an aftermarket one. Im planning on putting in a triple a pillar pod with an AEM wideband uego, interceptor and replacing the stock boost gauge with a glowshift boost gauge.
Old Jul 9, 2009 | 01:10 AM
Bszondi's Avatar
extremely easy to do.. even easier if its electrical.. but i would say go mechanical.. there is a how to on here im sure!
Old Jul 9, 2009 | 01:41 AM
Snakes709's Avatar
easy to swap them but you might have the same issue im having right now...iiunno tho. I had a 140kpa gauge (20psi)....im hitting 130kpa (18psi) of boost....i changed to a 30psi gauge from the ss/tc cuz im installing a TVS....still have the m62 on and its saying im hitting 25psi. Computer doesnt know i swapped the gauges and its sending the needle to the same spot. So just make sure its the same measurements
Old Jul 9, 2009 | 01:54 AM
Chad92's Avatar
How is this in the How To section??
Old Feb 5, 2012 | 09:52 PM
CannonBalt's Avatar
I just did it today. If you have any questions PM me and i'll help you
Old Feb 17, 2012 | 11:03 PM
frostybolt08's Avatar
hey man i wanna do the triple gauge pillar and wanna do a boost gauge wideband and oil pressure. can i take out y stock boost gauge and swap it with another? let me kno and how to do it, thanks!
Old Feb 17, 2012 | 11:14 PM
CannonBalt's Avatar
Yes you can take out your stock boost gauge, but you won't need the wiring for it, you will be supplied with everything when you get the new gauge.
I made this lastnight. It's super easy. Power the gauge, and tap into the boost line with a T fitting.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
brandon04
Oct 21, 2015 07:04 AM
Sep 27, 2015 08:53 PM
