Compression?
Old Mar 30, 2007 | 08:52 PM
blackgloves's Avatar
Compression?
yeah, I got all kinds of questions today
what compression is the SC'd 2.0L
Old Mar 30, 2007 | 08:53 PM
RedSSBaltSC's Avatar
9.5:1
Red2.4SS/SC's Avatar
X2^^^^^
Old Mar 30, 2007 | 08:54 PM
Originally Posted by Red2.4SS/SC
X2^^^^^
Red07SSNA's Avatar
Originally Posted by RedSSBaltSC
9.5:1
Have you done all your mods yet.
Old Mar 30, 2007 | 08:55 PM
are these motors forged?
Ive done nothing
what compression is the stock motor, yall are confusing me
Last edited by blackgloves; Mar 30, 2007 at 08:55 PM. Reason: Automerged Doublepost
No, PM me and I'll let you know my situation.
Old Mar 30, 2007 | 08:56 PM
9:5:1
XM15's Avatar
stock compression ratio is 9:5:1
Old Mar 30, 2007 | 08:58 PM
any more questions? I'm 2-0 so far
Old Mar 30, 2007 | 09:01 PM
forged internals stock or not?
Red07SSNA's Avatar
On the way!
Old Mar 30, 2007 | 09:02 PM
...ok 2-1 now. I'm not postive on that one
Old Mar 30, 2007 | 09:03 PM
oh you let me down...
j/k
anyone know if our motors are forged?
Old Mar 30, 2007 | 09:04 PM
I do know that in the build book they only use the LSJ pistons to 300hp
Old Mar 30, 2007 | 09:09 PM
Red07SSNA's Avatar
Ecotec supercharged 2.0-liter specifications
Part number: 12499466
Type: 2.0L I-4 supercharged
Displacement: 1998cc (122 ci)
Compression ratio: 9.5:1
Valve configuration: dual overhead camshafts (4 valves per cylinder)
Assembly site: Kaiserslautern, Germany
Valve lifters: hydraulic roller finger follower
Firing order: 1 - 3 - 4 - 2
Bore x stroke: 86 x 86mm
Fuel system: sequential fuel injection with high pressure (56 psi)
Horsepower: 205 hp @ 5600 rpm
Torque: 200 lb-ft (271 Nm) @ 4400 rpm
Fuel shut off: 6500 rpm
Applications: pre-emissions and off-road applications
MATERIALS
Block: cast aluminum with cast iron cylinder liners
Cylinder head: cast aluminum
Intake manifold: aluminum
Exhaust manifold: cast iron
Crankshaft: forged steel with induction hardened fillet
Camshaft: cast iron
Connecting rods: forged steel
Additional features: extended life platinum spark plugs and coolant
electronic throttle control
Old Mar 30, 2007 | 09:19 PM
MATERIALS
Camshaft: cast iron
You the man... Im giving you rep points for this
Tupp
Sep 30, 2015 08:18 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
jmelton327
Sep 26, 2015 10:04 PM
DisJuan
Sep 7, 2015 04:24 PM
