could i run?
Old 03-12-2008, 03:40 PM
SS FREAK's Avatar
could i run?
#60's injectors with out a tune for right now or will it hurt my car.. also is there a tuner in florida that could tune me?
Old 03-12-2008, 04:26 PM
RACIN_RANDY's Avatar
Don't do it you'll waste fuel, and possabilly damage something running rich. and with the price of it now... what part of Florida are you in??? there are meny accomplished tuners around, just need to know where you located???
Old 03-12-2008, 05:04 PM
aveoturbo's Avatar
u can do the bigger injectors. ur still only gonna pump a limited amt of fuel into your motor unless u tune it to put more in. its like the aveo, i can use injectors from a v8 trailblazer and put them in place of my original ones but unless i have a setup to force more fuel thru them, it wont do much of anything except let u say that i have blah blah injectors. my .02
Old 03-12-2008, 05:05 PM
anthonyS88's Avatar
where in fla?
Old 03-12-2008, 05:07 PM
Red2.4SS's Avatar
Injector change w/o tune is very bad!!! Your ECM cannot properly control the fuel.
mkulrey13's Avatar
bye bye balt.
Old 03-12-2008, 05:45 PM
fr33k's Avatar
?? I hope your kidd'n. Bigger injectors means that for each pulse the PCM gives the injector, more fuel can flow through the injector. It's like putting bigger jets in the carbs on the older vehicles. The bigger they are, the more they flow.
If your PCM is not not tuned to use it, you will be dumping WAY too much fuel than you need. You don't force more fuel through them. More fuel will FLOW through them per pulse anyways.
Old 03-12-2008, 06:19 PM
CobaltWithMods's Avatar
its like throwin a hotdog down a hallway basically
Old 03-12-2008, 06:38 PM
aveoturbo's Avatar
i had it twisted, thanks for the correction.
Old 03-12-2008, 07:16 PM
loll
Old 03-13-2008, 07:47 PM
tru2nrtt777's Avatar
Or a pencil down a mineshaft?
Old 03-13-2008, 09:39 PM
INFE's Avatar
i dont think it would run at all without a tune.
Sl0wbaltSS
11-21-2018 11:11 PM
Zharrington_2010LNF
02-08-2016 01:43 PM
tomj77
10-04-2015 11:39 AM
dieGone
10-01-2015 06:27 PM
Extremespeed
09-29-2015 04:34 AM
Quick Reply: could i run?
