Dealership oilchange....
Originally Posted by SilverSS/SC
If it got down to replacing a engine , you bet your a$$ GM reps would request to have the oil analized
Originally Posted by BeastlyTA
So they are going to pull out their handy dandy chemistry set and test the oil to make sure its Mobil 1 synthetic.........yeah I think not.
No the dealer won't but GM corporate might very well do that when you try to warrenty your whole engine.
And you best believe they can tell the different brands apart.If you buy the high performance car you better be ready to put the high performance parts and consumables into it.
LSX RWD S/C conversion
Originally Posted by zinner
.....If you buy the high performance car you better be ready to put the high performance parts and consumables into it.
Originally Posted by SilverStreak
So... what's the point of buying good oil and a cheap filter?
Isn't that kinda counter-productive?
the point of that is that cheap filters such as fram work better with synthetic oil, bc they are usually single-layered. with synthetic, the less it filters the better, especially with mobil one. you can really mess up your engine over the long run by making your synthetic oil "too clean". i wish i could explain it as well as the mechanic that schooled me on this, but you just have to realize that synthetic is nothing like regular oil and the rules are different.
I would say it should be Mobil for the SS, the motor was designed for it and Mobil synthetic does not compare to any other synthetics out there, its really good **** thats why they charge more for it. There are other GM products that use Mobil 1.
As for the instructions:
I have personally read the instructions in a GM service manual and the SS oil change is the same as in any 2.2 ECOTEC engine except that you should lossen one of the supercharger pipe bracket bolts so that you can move it out of the way.
oh just a tip, if you want to save money at the dealership go and get a case of Mobil 1 at costco/samsclub and provide the oil for the dealership. Thats if you have a membership, if not then i don't think it would be worth it for you to get the oil there, try walmart too. Dealerships always have a higher markup.
i paid $43 for mobil1 and a fram filter to do it myself. the first time i did it i thought i was going to have to remove the supercharger to access the filter, but i lucked out and found a long pair of channel locks. it barely fit and i could only make 1/4 turns, but it was well worth the money and time saved, and knowing it was done right.
I hate how the cap is cheap plastic that can strip very easily.
DO NOT GET FRAM FOR GODS SAKES! Fram is the worst filter out there because one of the pieces is made out of cardboard.
All of these filters are made by FRAM avoid them at all costs!
Fram Extra Guard (std)
Fram Tough Guard (different media?)
Fram X2 (Silicone ADBV, Fuzzy media)
Fram Extended Guard(same as the X2)
Mileguard (Jiffy)
Honda (although some are alleged to be made by Filtech)
Chrysler line up except for the Cummins
Penzoil
Deffense
Canadian Tire
Personally I go for AC Delco or Wix (Napa line), Purolator is also good!
http://theoildrop.server101.com/ubb/...c;f=6;t=002456
Mileguard (Jiffy)
Penzoil
Deffense
Canadian Tire
Talking about Fram filters, A faw years ago I did bunch of maintance work on a Chevy P/U., plugs, wires,cap, rotor, fuel filter and air filter. Well after words took it out for a test drive, damn thing couldn't get out of its own way! After beating my head against the wall for a few days, I found out the air filter was severelly restricted. The paper element was too backed together. Haven't purchased any Fram products since.
i change my own oil...kinda tricky the first time on the ss, it costs me $43 to do it myself using the mobil1 and a cheapie filter
Located just off US60 and Superstion Spring Blvd. ask for Scott
Originally Posted by d_backer1
For $10 more @ Superstiton Springs Chevy will change it for you using Mobil 1 oil and OEM filter
When did you buy your SS? Does it have the yellow inserts. Cuz I think I may have almost purchased your exact car
'00 Cavi ghost flames done by myself
i was told by a mechanic in the family (25+yrs experience) that with the superior synthetic oils such as mobil1, you NEED to use the crappiest filter you can find. a good filter can actually rob certain synthetics of their lubricating "properties"
i wish i could remember everything he told me, but bottom line= only use crap filter with mobil1. this may cause a few bs flags to go up, but i encourage anyone to first...find a mechanic with that much experience and ask him.
Ready for some street racing tonight, flackenwhat?
i havent seen you at the club in a while! i read on here somewhere you got in trouble with the mrs....you comin back out anytime soon? srt4 just smoked an evo from a roll tonite, we did like a 20 car cruise down bell and the evo got boxed in then started talkin smack. our 2 srt's did 145 down t-bird a few nights ago...good times. the guys at the club told me a black ss came out with 4 ppl, they got out didnt talk to anybody, then left...were they lookin for me?
