For discussion of all things Powell!!
Old Aug 11, 2015 | 03:09 PM
  #1526
colodude18's Avatar
MID WAY thats the best damping . either end stiff or soft is over or under damped. Wangspeed runs the same way, midway at 4 corners
Great info! I'm still running mine on full soft. Haven't had time to fine-tune suspension due to more pressing issues at the track like overheating :/
Old Aug 11, 2015 | 03:21 PM
  #1527
Everyone is going to be changing set up now lol
Old Aug 12, 2015 | 04:44 PM
  #1528
bmxracerchamp12's Avatar
i ordered my yyz's a few months ago and never received any spring sleeves. i guess ill see how it is for now
Old Aug 12, 2015 | 06:48 PM
  #1529
Powell Race Parts's Avatar
we only started this a few months ago. If you would like some isolator material just email Tom at crate engine depot or gloria at powell raceparts (depending where you purchased them) and we will send you some free of charge. Or you can try my spray solution. Either way. I dont have the noise on my car and dont wrap them. Its weird. It for sure is the dead coils if you have a noise from the spring all being equal with a correct installation procedure.
Old Aug 12, 2015 | 08:45 PM
  #1530
yellowsupercharged06's Avatar
Johns car is perfect lmao
Old Aug 12, 2015 | 08:54 PM
  #1531
Lol i know huh
Old Aug 13, 2015 | 07:25 AM
  #1532
Staged07SS's Avatar
Administrator
Administrator
I will say this.... if you install the springs a certain way, you may end up with clunk. I had all my dead coils wrapped with tein silencers and I still had a rear passenger side clunk. I checked the twist beam axle bushings and they checked to be ok, so I decided to look at spring orientation. My passenger side rear spring was turned slightly different in the perch from the drivers side. I turned it to match, and haven't had a clunk since.
Old Aug 13, 2015 | 09:24 AM
  #1533
I had what Staged did with my pedders ... only with a passenger in the car though. Never really cared too much since i rarely have anyone else in the car with me. But good to know.
The silencers that CED has i installed yesterday and the clunk is gone. Have not tested it with a passenger though.
Old Aug 13, 2015 | 09:45 AM
  #1534
Staged07SS's Avatar
Administrator
Administrator
Great!! Glad they worked for you man.
Old Aug 13, 2015 | 09:55 AM
  #1535
dont know how long there going to last but its a fix for now lol
Old Aug 13, 2015 | 01:38 PM
  #1536
i havent had any noises from mine but everything is installed the same way (ocd in me) but i also havent pushed the car any. i have been busy lately and havent had time to enjoy it
Old Aug 13, 2015 | 11:49 PM
  #1537
Just installed my stage 3 face :P
Old Aug 14, 2015 | 05:58 AM
  #1538
YelCal7's Avatar
I don't have any clunks on my yyz springs. I put dead coils on the bottom, I noticed some guys put dead coils on the top and have clunks there. Maybe I'm wrong...Possibly I have a DEAF car! LMAO!
Old Aug 14, 2015 | 08:04 AM
  #1539
Thats funny knowing your situation lol
Old Aug 14, 2015 | 08:17 AM
  #1540
Staged07SS's Avatar
Administrator
Administrator
Dead coils should be up....
Here's what Powell said about it a while back:
"it matters when the springs fall out. The dead coils are designed to keep the spring in place when the twisting beam rebounds (droop) and the spring will try and often does pop out of the top spring locator nipple. The lower spring seat is easy, gravity keeps it in, but the top is the problem. As the CM spring loses rate over time, eventually the dead coils have insufficient spring rate to keep the spring in place over bumps when the beam drops down, and the spring can fall out.
so. dead coils up."
but since YYZ's aren't supposed to loose rate, I guess it doesn't matter.
I found spring orientation in the spring seat can cause a clunk sound as well.
Old Aug 14, 2015 | 08:52 AM
  #1541
YelCal7's Avatar
That's weird...I put on 1,400 miles trip on it. I had no problems with dead coil down on my car the whole trip and working like it should.
Old Aug 14, 2015 | 09:03 AM
  #1542
qfe
Old Aug 14, 2015 | 09:17 AM
  #1543
im curious as to what Johns Redline Setup is, motor wise.... anyone that knows want to chime in ?
Old Aug 14, 2015 | 10:24 AM
  #1544
Staged07SS's Avatar
Administrator
Administrator
TVS, 2.9 pulley or 3.1 (I forget), GMR ported head etc.
Old Aug 14, 2015 | 10:26 AM
  #1545
fuel ? cams ? any idea on power level ?
just curious to see how my car is going to do with the power as a track car that's all.
Old Aug 14, 2015 | 10:27 AM
  #1546
Staged07SS's Avatar
Administrator
Administrator
Stock cams.
I believe he said it makes 305 on pump and 320ish on race gas.
Old Aug 14, 2015 | 10:33 AM
  #1547
ahh ok thanks my man !
Old Aug 14, 2015 | 10:46 AM
  #1548
Staged07SS's Avatar
Administrator
Administrator
Welcome.
Old Aug 14, 2015 | 11:39 AM
  #1549
Well i had the dead coils on the bottom and had clunk (althought i dont think i would call it clunk, since it was more of a clicking sound) and i reinstalled them now with dead coils up and still has some clunk
Old Aug 14, 2015 | 11:57 AM
  #1550
Staged07SS's Avatar
Administrator
Administrator
Check the spring orientation in the spring seats. Try to match the drivers and passenger side.
