Does Cold Weather Cause Sounds And Vibrations?
Old Jan 26, 2007 | 11:08 AM
pvirga88's Avatar
Has anybody experienced weird sounds and vibrations comming from their suspension when it's really cold out.
This morning I had weird sounds and I even felt some vibration in my front passinger side suspension. I kinda felt like a mount was bad or something. Also I noticed that my rear brakes queek really bad when I go in reverse. It sounds like the brakes are sticking a bit. But it doesn't feel like it. All of this goes away when the car is driven about a mile or so, or when all the juices start to flow. This just started to happen as the weather began getting colder.
Has this happened to anybody else?
Is this a normal thing that occurs? or should I bring the car into the dealer?
I drive a 06 Cobalt SS/SC
Old Jan 26, 2007 | 11:17 AM
iwannagofast06's Avatar
i'm gonna say yes, but I was also hoping someone else could confirm this same thing, so don't quote me. But just this morning (for about the 4th/5th time this winter) my brakes have squeeked really bad and my shocks sound rough... almost rusted... going over bumps. I've also noticed it's harder to shift until everything is warmed up. My squeeking brakes don't go away until I've driven about 2 or 3 miles. The shocks sound and respond normal, though, after your estimated 1 mile. And I definitely do hear some moaning and groaning from the car in reverse.
Again, don't quote me... but I'm gonna say "yes" and thanks for confirming I'm not the only one.
(it's about 14*F here)
Old Jan 26, 2007 | 11:18 AM
BLKNSLVR06's Avatar
yes i have a Vibration in the cold. once i park it for the night and the next morning when im on my way to work i will get a thumping sound and a vibration as if the wheels are out of balance. then a few miles down the road (assuming once the tires warm up) the noise and vibration stops. i thought it was the tires out of balanced but i balanced them again. and also swapped out rims and tires and i have the same thing again and again in the cold. also i get the brake noise only sometimes though. but i wouldnt be too worried about it unless it get worse.
Old Jan 26, 2007 | 11:20 AM
D4u2s0t's Avatar
it depends exactly on the sounds, but you have to realize that parts go from freezing cold to burning hot, so they're going to expand, contract, and make sounds... my coolant was 16 degrees when i started the car, and in a matter of minutes it goes from 16 to 190... it's the same with all the other parts... even if the car is warmed up, the brakes are still freezing, along with the other parts...
1stbluSS's Avatar
Yes the cold air makes the suspension contract just a little more than normal. Then when you get in the car and take off and the suspension is warming up you hear the creaks and get the vibes... thats my theory and im sticking to it !
pvirga88's Avatar
**** your alot warmer than me. When I left my house this morning it was 6.
Old Jan 26, 2007 | 11:22 AM
fballman1987's Avatar
i noticed that it is harder to shift whe it is cold out but have yet to notice sounds.
Old Jan 26, 2007 | 11:24 AM
pvirga88's Avatar
I was thinking the same thing. My car usually warms up in 5 to 10 minutes depending on the temp.
This is acually my first winter with it so I never experienced 6 degree weather with it until now.
Thanks for the input.
Old Jan 26, 2007 | 11:27 AM
BLKNSLVR06's Avatar
16*degrees and after sitting all night the motor is a little noise this morning... made me listen when i started it... since the old lady usually does it haha
Old Jan 26, 2007 | 12:08 PM
PuSha050's Avatar
and i, sadly, was walking for 15 minutes to my car in that weather... and yea my car makes a butt load of noises in the cold, especially the rear suspension
Old Jan 26, 2007 | 12:14 PM
FlintIonQC's Avatar
Just so you all know, I had this grinding noise coming from my front passenger side tire suspension area whenever it got below freezing. It was a plastic to road kinda of grinding noise. I let Saturn have it overnight so they oculd drive it this morning when it was 3 degrees outside. It ended up being a torn front sway bar bushing that had no lubrication due to its design and tore. They replaced it with new ones, and apparently the supplier has redesigned them recently because they did not look the same. I have an Ion 3 QC with the FE3 suspension. Just thought you all should have the info.
Old Jan 26, 2007 | 12:16 PM
hispano1's Avatar
ive had similar experiences and still do to this date, the squeeky back break is normal...the dealership i went to said it's normal in the cold and if it's been sitting in the cold for a while and start reversing it'll make that noise and for the shocks, i get that too, first speedbump i see in my alley it sounds like my shocks are rusty but they arent but after that, like literally 2 mins after of just driving it, then there's no more noise anywhere...
Old Jan 26, 2007 | 12:25 PM
css9450's Avatar
I've never had a car that didn't make some sort of extra noises when it was really cold. Everything should return to normal pretty quickly as it warms up; if not then maybe you should take it in.
Old Jan 26, 2007 | 01:58 PM
lightsout's Avatar
I agree with the above poster. I think most cars make funny noises and run rough when it's really cold. My friend has a Lexus and it does the same thing. I don't worry about it because once the car is warmed up it's Ok.
Old Jan 26, 2007 | 02:04 PM
OniMirage's Avatar
the car will make noise in the morning when everything is warming up. A lot of times you will here lots of cabin noises cus the tires are cold and are stiff so vibrations are higher than normal
Old Jan 26, 2007 | 07:36 PM
FlintIonQC's Avatar
There is a TSB for the front sway bar bushings on FE3 suspensioned cars
Old Jan 27, 2007 | 12:02 AM
tiny's Avatar
dont forget, there could be snow stuck in some places that would cause noise..
Old Jan 27, 2007 | 01:36 AM
sensesfail99's Avatar
I have the same problems. Its embarrassing
06MetallicBalt
Jul 20, 2025 08:47 PM
turbochargedss2012
Sep 20, 2023 12:17 PM
biniecki
Oct 25, 2015 02:23 PM
jimbofug007
Oct 2, 2015 12:06 PM
Tupp
Sep 30, 2015 08:18 PM
