Dyno runs/tuning
Old Jul 6, 2011 | 11:31 PM
crazycarl2010SS's Avatar
Dyno runs/tuning
Hey guys. Im going to the dyno tomorrow and i was wondering what gear you guys have used. The first time he had it in 4th and I was wondering if another gear would be more accurate/better.
Old Jul 6, 2011 | 11:39 PM
chood711's Avatar
i have always done my pulls in 3rd.
Old Jul 7, 2011 | 02:15 AM
well since he did it in 4th already should i just keep it consistant or ask him to do it in 3rd
Old Jul 7, 2011 | 02:22 AM
Omnigear's Avatar
do 1 of each n see which is higher =p
Old Jul 7, 2011 | 12:30 PM
09CobaltSS1's Avatar
3rd = underdriven, 4th = slightly overdriven
generally with 4th being slightly overdriven it should give you some slightly better power numbers in a turbod application.... assuming your clutch can handle the extra drivetrain load in the lower-mid rpm range that is.
I personally have to do 3rd gear pulls otherwise my stock clutch slips something fierce
Old Jul 7, 2011 | 12:34 PM
BYT*SS*TURBO's Avatar
It will be minimal difference between the 2 unless you trigger the COT protection in 4th.
Old Jul 7, 2011 | 12:45 PM
08SSTCRD's Avatar
What is COT protection??
Old Jul 7, 2011 | 12:46 PM
Everyone loves a good 4th gear torque spike to brag about peak numbers though Nick!
Old Jul 7, 2011 | 12:58 PM
it makes no diff lol
Old Jul 7, 2011 | 01:18 PM
Cat Over-temp protection
No? Seems to me that loading the turbo in an overdriven gear would give you a larger torque spike as compared to an underdriven gear. It sure does it well in diesel applications at least. Granted we're talking a much larger and laggier turbo, however it is still a turbo setup non the less.
Ehh oh well..
Old Jul 7, 2011 | 01:50 PM
we made 447wtq in 3rd gear, seems to work just fine lol
Old Jul 7, 2011 | 02:13 PM
Come on Nick. Defend your point better than just brushing what I have to say off as bupkis and throwing random numbers at me man. I like to think you know better than to assume I'm just going to make **** up and throw it out there like that.
Granted I may not know as much as you about every performance application, but everything I've ever known about dynoing a turbo vehicle has always dictated that loading up the turbo in a taller gear will yield higher power numbers.. especially torque. Whether it is only 5-10whp or not. Hense my earlier statement: "generally with 4th being slightly overdriven it should give you some slightly better power numbers in a turbod application"
I'm not trying to be an argumentative jerk here by any means btw. You're just coming off as a tad condescending
Old Jul 8, 2011 | 09:28 AM
I defended it.. You can make tq just fine in 3rd and we saw no difference in 4th. What else do I need to say here? lol
Old Jul 8, 2011 | 09:51 AM
Gremlin85's Avatar
Just throwing out my .02 cents...
I've done about a couple dozen or so dyno pulls on my car and there is almost no difference between 3rd and 4th gear pulls besides the fact that 4th takes longer lol. When I was stock and putting down the base numbers (in my sig), they came up within 1-2 hp and 1-2 tq between 3rd and 4th gear. We did 1 pull in 4th and the guy doing the dyno said it took too long to do the pull... I have no idea what he was going on about, but I digress. He then did the next 2 pulls in 3rd and the numbers were pretty much exactly the same. Tuned, they came up almost the same, within 1-2 hp and tq from a 3rd gear to a 4th gear pull. These cars are very consistant.
Was that long enough of an explenation?
Jan 12, 2016 12:01 AM
maliki778
Oct 1, 2015 07:39 PM
footballplaya3k
Sep 28, 2015 11:14 AM
Sep 27, 2015 08:53 PM
Cptnslo
Sep 24, 2015 09:32 AM
