electronic throttle limited traction
Old Nov 30, 2011 | 03:45 PM
nhanson's Avatar
its just how the car is set up in the stock tune. Abuse protection
Old Nov 30, 2011 | 04:17 PM
breds2k's Avatar
^i really think thats probably all it is. Only way around it is a tune I amagine.
Old Nov 30, 2011 | 04:21 PM
drumrush's Avatar
I'm tuned and it still does it
Old Dec 2, 2011 | 08:23 PM
Phil424's Avatar
I have noticed this as well. Its purposely put there to keep from abusing the car. Gotta love drive by wire systems.
Old Dec 4, 2011 | 04:16 PM
nhanson's Avatar
Then the tuner missed something. I no longer have any limitation. I can burn 1st gear and shift to 2nd and it will grab in 2nd. 0 shut downs.
Old Dec 4, 2011 | 04:51 PM
-TurboSS-'s Avatar
It's torque management. There is an option to turn it on/off when you do a tune.
Q: What is Torque Management?
A: This feature was designed to extend the service life of automatic transmissions by removing a certain amount of timing advance temporarily before beginning the shift between gears. The effect is there is less wear and tear on the transmission because not as much power is being run through the transmission while the clutches and bands are engaging/disengaging.
However, TM also reduces performance, and removing it, especially in the trucks, can produce a noticible improvement in performance. Trifecta Perfomance can adjust or eliminate the torque management in your 99+ Gen III PCM programming. Just let us know on the ordering form if you'd like it adjusted or removed completely.
Old Dec 4, 2011 | 06:37 PM
drumrush's Avatar
You sure were talking about the same thing? Mine shuts down well before It should be shifting
Old Dec 4, 2011 | 06:48 PM
nhanson's Avatar
Mine did too. It would spin for a split second, kill power, then after 15 secs let the car go WOT.
Old Dec 4, 2011 | 07:19 PM
drumrush's Avatar
Thats ****** awesome, I've been pissed because I thought there was nothing I could do about it
Old Dec 4, 2011 | 07:25 PM
nhanson's Avatar
Talk to vince.
Can you tell me your shift points, pressures, and times?
Old Dec 4, 2011 | 07:58 PM
  #36
drumrush's Avatar
All that is stock right now
Old Dec 4, 2011 | 08:20 PM
  #37
nhanson's Avatar
ah ok. get it done...huge difference
Old Dec 5, 2011 | 03:16 PM
  #38
drumrush's Avatar
i talked to vince today, and he said that torque management DOES NOT cause this, and he strongly recommended that i did not turn it off because it would tear up my transmission with all the extra power im making right now. however, he said that he might have an idea what i was talking about with the power cutting out when the tires spin. he sent me an updated tune, and it was fixed. i tested it out by spinning my wheels up to 80
Old Dec 5, 2011 | 03:34 PM
  #39
breds2k's Avatar
your car now hates you. I wouldnt spin the tires like that but will in the snow I love to power through New England winters but just for the sake of pulling into traffic it might be dangerous so I am going to consider this.
Old Dec 5, 2011 | 03:38 PM
  #40
drumrush's Avatar
i will never do it again, but i got a little carried away lol. but all im trying to say is that vince will take care of it if you explain to him what you want done
Old Dec 5, 2011 | 05:01 PM
  #41
nhanson's Avatar
i doubt TQ management is saving your trans. he just needs to adjust shift times and pressures so its a bit quicker.
Quicker shift = less clutch slipping
i like to see how fast the speedo climbs in the snow
Old Dec 5, 2011 | 05:03 PM
  #42
drumrush's Avatar
its not even snowing here. 0-85 in about 4 seconds in the rain haha
RaginChopsuey
Oct 27, 2015 01:27 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
