error codes
Can someone please help me with some errors codes i dont want to spend a fortune fixing it...
p2431 Secondary air injection system sensor
p0134 Ho2 sensor circuit condition sensor 1
p0030 oxygen sensor heater condition check repair
p0135 h02s11 heater condition sensor 1
Did you have the codes when you swapped it? You should have cleared them once you swapped it. Its also possible that you got a bad sensor or messes up the wiring during install. Clear the codes and see if they come back. If the do, check the sensor/wiring.
OrangeCoba
Sep 25, 2015 06:06 PM
