Going to look at SS tomorrow, help!!!
Old Nov 5, 2008 | 08:36 PM
NastyFastSS's Avatar
Question Going to look at SS tomorrow, help!!!
It's a 2006 SS/SC
Has 47,000 miles on her and looks to be in great shape.
yellow paint with black/yellow interior
Still has warranty. Not sure if it's a 60,000 or 100,000
Fully loaded and the dealer is asking 10k for her!!!
Anything I should look out for? anything under the hood? door seals? Need advice!
1G1AP14P667767177 - Heres the Vin#, If anyone has a Car Fax I would really appreciate checking this car out.
Thank you all!
Old Nov 5, 2008 | 08:59 PM
DNewman's Avatar
I would request that the dealership do a carfax to save you the money. Just make sure all the lines are straight all gaps (hood to fender and door to fender) are even and look for wear on the shifter and clutch pedal. Just some things I looked at when shopping around. Good Luck!
Old Nov 5, 2008 | 09:04 PM
07cobalt4life's Avatar
someone that works for gm here can get you a print out of all the warranty work that has been done to the car or u can go to a chevy dealer and they can get it
Old Nov 5, 2008 | 09:08 PM
I'll probably go to the chevy dealer before I go, It's on the way. Thanks for your advice guys.
Old Nov 5, 2008 | 09:28 PM
joemama's Avatar
i say spend another 2-3k get the G85 package with less miles. Its not on the stock warranty because GM gives a 3 year 36k warranty i thought. Maybe a extended warranty which is good to a point. BUt if thats the case you might as well drop it and get one from National They are considered the best.
At 10k that is pretty cheap so i would definately find out why. Either way be cautious dont buy it right off the bat. I bet its 10k plus more for the warranty and **** as well. If you get it all for 10k good deal but dont spend more than it
Old Nov 5, 2008 | 10:41 PM
rukkee's Avatar
Originally Posted by NastyFastSS
It's a 2006 SS/SC
Thank you all!
NOT a carfax but a GMVIS, it basically a system that keeps track of what warranty work has been done , and give dealers access to the build sheet and other info.
VIN : 1G1AP14P667767177
VEHICLE INFORMATION
Merchandising Model : 1AP37 -2006 COBALT SS SUPERCHARGED COUPE
Warranty Start Date : 04/24/2006
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : ROBERT FENDER CHEVROLET
PO BOX 7670
TIFTON , GA 31793-7670
(912) 384-3980
Selling Source : 13 - CHEVROLET
Site Code :
Business Associate Code :
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Vehicle Has No Current Record Of Outstanding Campaigns
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
OnStar Equipped No OnStar Status N/A 667-8271.
XM Equipped Yes
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 04/24/2006 21 miles 04/24/2009 36021 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 04/24/2006 21 miles 04/24/2012 100021 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 04/24/2006 21 miles 04/24/2014 80021 miles
36/36000 FEDERAL EMISSION 04/24/2006 21 miles 04/24/2009 36021 miles
60/60000 POWERTRAIN - U.S. LIMITED WARRANTY 04/24/2006 21 miles 04/24/2011 60021 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
09/02/2008 302122 # K3187 - FORK AND/OR SHAFT, SHIFT - 5TH - R&R OR REPLACE 47063 miles
04/25/2007 093119 # D3088 - HOSES AND/OR LINES, REFRIGERANT - COMPRESSOR SUCTION AND D 21813 miles
12/05/2006 090719 # J9994 - CUSTOMER CONCERN NOT DUPLICATED 10098 miles
12/05/2006 090719 # N1720 - FUSE - REPLACE 10098 miles
05/08/2006 087206 # N6600 - WIRING AND/OR CONNECTOR - BRAKE SYSTEM/TRACTION CONTROL - 1422 miles
01/17/2006 A67177 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VEHICLE BUILD
Gross Vehicle Weight Rating : 1758 kg (3876 lb) Order Number : JSXZZT
Build Date : 01/17/2006 Build Plant : 167A
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AK5 - DRIVER & RIGHT FRONT PASSENGER AIR BAGS
ALV - SENSOR INDICATOR
AR9 - DELUXE FRONT BUCKET SEAT
ASF - AIRBAGS, SIDE HEAD-CURTAIN
CF5 - ELECTRIC SUNROOF W/MAP LIGHTS
C67 - ELECT. FRONT AIR CONDITIONER
DG7 - BODY COLOR POWER MIRRORS
DT4 - ASHTRAY AND LIGHTER
FE5 - SUSPENSION
FE9 - 50-STATE EMISSIONS
FQ7 - 4.05 FINAL DRIVE TRANSAXLE RATIO
IP6 - INTERIOR TRIM DESIGN
JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
K09 - 120 AMP GENERATOR
LOD - ASSEMBLY PLANT - LORDSTOWN,OHIO
LSJ - 2.0L DOHC SUPERCHARGED 4 CYL
MM5 - 5 SPEED MANUAL TRANS W/SHORT THROW SHIFTER
MU3 - MANUAL 5 SPEED TRANSMISSION
NP5 - LEATHER WRAPPED STEERING WHEEL
NT9 - FED EMIS SYS, TIER 2 PHASE-OUT
NW5 - 18" ALUMINUM WHEELS
QTJ - P215/45R18 BW TIRE
RE8 - UPGRADE ORNAMENTATION
R6P - PREMIUM PAINT
R8K - *******************************
R9N - HEATED LEATHER APPOINTED FRONT BUCKET SEATS
R9U - GM ACCESS - AUTOBOOK IDENTIFIER
SLM - STOCK ORDERS
UQ3 - PIONEER 7 SPKR AMPLIFIED SYSTEM
US8 - AM/FM STEREO W/CD & MP3 (REPLACES STD/OPT RADIO)
U2K - XM SATELLITE RADIO-SERVICE FEE EXTRA. 1ST 3 MONTHS INCL.
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
1SZ - OPTION PACKAGE DISCOUNT
19I - EBONY
196 - EBONY WITH YELLOW INSERTS
2SS - 2SS BASE SUPERCHARGED COUPE PKG
34U - RALLY YELLOW
6AJ - FRONT SPRING
7AJ - FRONT SPRING
8AC - REAR SPRING
9AC - REAR SPRING
Š 1998-2005 General Motors Corporation. All Rights Reserved.
Old Nov 5, 2008 | 10:44 PM
Acey's Avatar
Wow, I wish there were SS for 10k around here. Good luck.
Old Nov 5, 2008 | 10:52 PM
3fo893013L's Avatar
These cars don't hold value as they shouldn't it's an econobox. I sold mine for $8,500 with like 8x,xxx miles on it.
Old Nov 5, 2008 | 10:53 PM
link_630's Avatar
i'm up in new york and i got a steal on my 06 ss 12,500 when all the other dealers were at 18,000. it only had 36,057 miles on it when i was about to sign the papers i told them i wasn't going to unless i was able to get the extended with it so the guy changed the milage on the paperwork to 35,957 now if anything goes wrong and the warrenty company doesn't want to cover it then the dealership will due to forgery lol. i'm not very nice when it comes to this kind of stuff. i would say spend some extra and ask if you can take it to your mechanic if they agree you can take it to chevy and have them take a look at it.
Old Nov 5, 2008 | 10:58 PM
07LaserBlueSS's Avatar
Carfax is clean.
http://www.carfax.com/viewEmailRepor...i3&language=EN
Old Nov 5, 2008 | 11:01 PM
Acey's Avatar
sucks for buying things
Old Nov 5, 2008 | 11:15 PM
R&C_rallySS's Avatar
Something seems fishy about the price.
Buy this one =) https://www.cobaltss.net/forums/complete-cars-101/fs-06-ss-sc-fully-loaded-g85-9k-miles-95672/
Last edited by R&C_rallySS; Nov 5, 2008 at 11:15 PM. Reason: Automerged Doublepost
rukkee's Avatar
I wonder if they replaced the tranny or tried to fix it themselves? That could account for some of it .
Old Nov 5, 2008 | 11:20 PM
I know that 10k price tag seems strange, I'm hoping nothing is wrong with the car. I don't think there is only because it was listed at around 13k, then within a week it dropped to 10k! No one wants a SS/SC in my area I guess...Thanks LaserBlueSS for the carfax. Makes me feel A LOT better! And thanks to all you guy's for your inputs. Will let you all know how it goes tomorrow!!!
Old Nov 5, 2008 | 11:43 PM
joemama's Avatar
theres a reason they dropped it 3k in a week
dealerships will sit on cars for a month or so before price drop
Old Nov 5, 2008 | 11:52 PM
link_630's Avatar
i bought mine a couple hours before the dealership was sending it to auction nobody seems to want these type of cars anymore they all want strait up fuel milage
Old Nov 6, 2008 | 12:06 PM
rukkee's Avatar
Winter is coming too, most dealers try and get rid of their sporty cars now rather than let them sit all winter on the lot. I know our cars aren't sport's car per say but they are from a dealers perspective.
Old Nov 6, 2008 | 10:10 PM
There was major traffic on the local HWY so I wasn't able to make it before they closed. I called the guy and asked why it's priced so low. He said they have had it for a couples months and they want to get rid of it for new invetory. I can only hope thats why it's priced so low lol.
hacadacalopolis
Oct 28, 2015 06:09 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
n20saturn
Drag Racing
19
Oct 6, 2015 12:38 PM
dennis69
Sep 17, 2015 12:52 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
