Goo Gone??
Old Nov 28, 2006 | 02:10 PM
hardtocope's Avatar
Goo Gone??
I went to walmart to buy goo gone and there are two types. One is in a rectangular bottle that can spray which just says goo gone and the other is like in a windex bottle that says goo gone pro gel? Which one is better, the goo gone pro says it might not be safe for automotive paints.
Old Nov 28, 2006 | 02:11 PM
Imlikedrpepper's Avatar
Do not use on automotive paints, you wont like what will happen if you leave it on there too long.
Old Nov 28, 2006 | 02:14 PM
Halfcent's Avatar
I'm old school
One is just a gel form, they do the same thing. I prefer the original and a clean cloth.
You can use it on a car as long as it's clear coated, which most all cars are anyway. Just be sure to clean with water afterward. It will haze if you don't wash it.
Old Nov 28, 2006 | 03:04 PM
Acidangel_5.0's Avatar
get the Stoner removal stuff.. best stuff i have ever had.. gets everything off and doent hurt the paint..
http://www.tarminator.com/
Old Nov 28, 2006 | 04:49 PM
1BadBlueSS's Avatar
What are you using it for??? if its tar your taking off....use WD_40
Old Nov 28, 2006 | 06:25 PM
rally's Avatar
Its probly for debading, it works the best to get the "goo" off. (intentinal pun)
Old Nov 28, 2006 | 08:28 PM
hardtocope's Avatar
i was considering just guying the 3m adhesive remover instead of the goo gone.. has anyone used the 3m for debadging?
Old Nov 28, 2006 | 08:32 PM
tcolli17's Avatar
Gas or WD-40 will work. If you use goo gone, make sure it is a yellow liquid. ALL solvents must be removed as quick as you can to make sure you don't damage your finish. DO NOT use goof off or acetone. Goof off is just xzylene which will eat right through your clear coat.
Old Nov 28, 2006 | 08:38 PM
rally's Avatar
Never use gas on paint, easiest way to strip off the clear coat and paint is by using gas.
Old Nov 29, 2006 | 12:03 AM
melvich18's Avatar
I used the 3M adhesive remover when i took off my badges. And it worked pretty good, but what i couldnt getr off that was left i used Easy Off oven cleaner.
07cobaltowner
How to Guide
55
Jun 9, 2009 11:47 PM
InitialG
Show & Shine
13
Sep 2, 2008 10:17 PM
deuce
Aug 11, 2008 03:45 AM
Bumblebalt
How to Guide
Nov 16, 2007 04:40 PM
HiSpdPursuit
Jan 26, 2007 07:20 PM
