Header Install Question
Old Jun 16, 2015 | 10:37 PM
UnkleRaRa's Avatar
I want to tackle my header dp this weekend. Im installing a CTI mid length and DP. I've read the how to's and am comfortable doing the work. I noticed in the how to for the long tube header, you have to remove the valve cover to drop the header in from the top.
My question is, does removing the valve cover make it any easier accessing the bolts for the exhaust manifold? Would it be worth removing? Any advice would be appreciated.
Old Jun 17, 2015 | 07:29 AM
Staged07SS's Avatar
Administrator
Administrator
You do not need to remove the valve cover to install the CTI header.
You can access a good portion of the bolts from the top side with a 13mm socket. Jack the car up, and get the remaining bolts from the bottom.
Install is the reverse of removal. Simple.
Old Jun 17, 2015 | 10:45 AM
UnkleRaRa's Avatar
Perfect!
Thanks Staged.... helpful as always :
Old Jun 17, 2015 | 10:47 AM
Staged07SS's Avatar
Administrator
Administrator
Perfect!
Old Jun 17, 2015 | 10:56 AM
We got my zzp longtube header on without the valve cover removal. Definately a tight squeeze butbits doable
Old Jun 17, 2015 | 02:22 PM
UnkleRaRa's Avatar
Did you go from underneath, or drop it in behind the motor?
Old Jun 18, 2015 | 07:11 AM
Staged07SS's Avatar
Administrator
Administrator
Go from underneath....
You will be driving yourself nuts trying to wedge it down from the top.
Old Jun 18, 2015 | 08:49 AM
kingofpoland's Avatar
yeah, if you go from underneath its a 20min job.. just hope them bolts are not rusty or you will have fun.
most likely will need couple extensions to reach the bolts on the header side.
Old Jun 18, 2015 | 10:56 AM
UnkleRaRa's Avatar
^^I hope not!
I spray my engine bay with krown twice a year, so hopefully it wasn't a was of time.... and money!
deviance
Nov 24, 2015 05:51 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Bohb
Sep 27, 2015 09:11 PM
