Help P 2187 Lean at Idle Code
Old Sep 27, 2012 | 04:27 PM
GotBoost08's Avatar
Question Help P 2187 Lean at Idle Code
Ok so i am having a problem with this P 2187 lean at idle code. It will trip the engine light on start up only, never while driving. Also this code wont come on every time i start my cobalt. I clear the code and it will come back on after like 5-10 start ups. Please help i cant figure out what this is from and my tune shop seems to be no help either.
Performance Mods: 08 TC with zzp upper and lower charge piping with MAF relocate, Injen cai, tial Q bov, zzp catless downpipe, dyno tuned via hp tuners 25psi of boost
The tune shop says that the code is accruing due to the tial Q but i already changed the spring to a much stronger one to hold the boost im running.
Old Sep 27, 2012 | 04:29 PM
umrdyldo's Avatar
What are your fuel trims?
Old Sep 27, 2012 | 06:34 PM
HyperFocus's Avatar
i had this issue a while back, dealer replaced HPFP and it went away but then came back..then they replaced the PCV valve or whatever its called and its been fine since
turbochargedss2012
Sep 20, 2023 12:17 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
tomj77
Oct 4, 2015 11:39 AM
jimbofug007
Oct 2, 2015 12:06 PM
DocSvensk
Sep 27, 2015 02:24 PM
