How hard is it to change Evap Purge Solenoid?
Old Aug 19, 2011 | 12:53 PM
Tstonee's Avatar
Long story short, I believe my Evap Purge Solenoid is causing some problems..
After speaking with my local dealer, they said the part was about $50.00.. and $150.00 to install it.. So $200.00 to have them order it and install it.
I figured I might ask.. How hard IS it to put a new one in?
Doing it myself would save me roughly $150.00
Old Aug 19, 2011 | 12:57 PM
hawlyns711's Avatar
sooooooooooper easy
Old Aug 19, 2011 | 01:00 PM
Pyros777's Avatar
The part plus shipping should come out a little under $50 from CrateEngineDepot:
Cobalt Supercharged Evap Vent Solenoid Valve 12597567 - Crate Engine Depot
and as for install, it is very easy.
1.) Remove any hoses and electrical connectors that are attached to it.
2.) Remove the solenoid with bracket from the vehicle.
3.) Disconnect the solenoid from the bracket, replace with new, and reassemble everything the same way you disassembled it.
Edit:
Sometimes pictures say it best:
Old Aug 19, 2011 | 01:45 PM
Staged07SS's Avatar
Administrator
Administrator
It's a piece of cake
Old Aug 19, 2011 | 02:10 PM
Tstonee's Avatar
Edit:
Wow... thank you very much.
Old Aug 19, 2011 | 02:19 PM
Tstonee's Avatar
Is the Red or the Blue thing I circled what i'm looking for?
and the yellow hose that I kinda outlined.. Can I jsut get any hose (right size of course) and replace that one? or is it like a "special" hose? The reason I ask is because it's cracking really bad and just looks like it should be replaced.
And yess... in the midst of circled and outlining that stuff.. i realize it looks like a *****.. and that was NOT intentional. I SWEAR!
Old Aug 19, 2011 | 02:41 PM
iboost's Avatar
^lmao
Old Aug 19, 2011 | 02:44 PM
Tstonee's Avatar
Originally Posted by iboost
^lmao
haha ****. I'll never get a response now b/c everyone will be laughing at my *****.
Old Aug 19, 2011 | 02:51 PM
Pyros777's Avatar
LOL its the red one.
Old Aug 19, 2011 | 03:07 PM
Tstonee's Avatar
What about the hose? Can I jsut get any hose and replace it?
Old Aug 19, 2011 | 03:10 PM
Pyros777's Avatar
Its 3/16" at one end and 1/4" at the other.
GM P/N 14091622 just in case you cant find what you need.
Old Oct 4, 2011 | 12:03 PM
pumm3l's Avatar
did you ever order the hose?
I put in an order to my local dealer with the part number 14091622 that Pyros777 suggested and when I went to pick it up it was this small plastic fitting not the hose.
looking at the exploded view in this diagram here:
AP ENGINE ASM-2.0L L4 PART 5 MANIFOLDS,SUPERCHARGER & FUEL RELATED PARTS (LSJ/2.0P);. Fits: 2006 Chevrolet Cobalt | Nalley Buick GMC Brunswick
it would seem that part 911 is the correct part:
12584338 HOSE. Turbocharger/Supercharger Air/Vac/Cooling. $47.44
if that's the case I might just buy a foot of 3/16" and a foot of 1/4" with a 1/4 to 3/16 reducer because $50 for a vacuum line is ridiculous. Just wonder if you ended up replacing it if you recall the part number.
Old Oct 5, 2011 | 01:44 PM
Pyros777's Avatar
Wow, sorry about posting the wrong part number. That is what came up on gmpartsdirect.
#2 is listed as part number 14091622. The picture is kind of vague though.
12584338 definitely seems like the right part, but at that price I would rather just buy some 3/16" hose and bore out one end until it fits on the 1/4" connector.
Old Oct 5, 2011 | 01:55 PM
150 bucks rofl
Old Oct 5, 2011 | 02:03 PM
pumm3l's Avatar
Yea I noticed that too on GMPartsDirect, they have it screwed up.
rather than bore out the hose I went and bought about a foot of 1/4" ID hose and half of foot of 3/16" hose then I picked this up:
Buy Dorman - Autograde Hard Vacuum Tubing Connector Diameter A 1/4" Dia. B 3/16" 47304 at Advance Auto Parts
Old Oct 5, 2011 | 02:27 PM
08_Slowbalt's Avatar
does anyone know if this is the same location as the LS cobalts? Mine is throwing a code saying this purge valve failure.
Old Oct 5, 2011 | 03:28 PM
Tstonee's Avatar
No, I never did replace it the hose... I replaced the solenoid in roughly 5 minutes though.....
Old Mar 19, 2012 | 09:46 PM
RobSSsedan's Avatar
Did you ever get it fixed im having the same problem?
Old Mar 19, 2012 | 11:27 PM
tpete763's Avatar
Yes its in the same position on the L61 engine. I had to replace mine about 2 years ago. Bought one new for about $25 shipped if I remember correctly.
EDIT: just noticed this thread is from last October
Old Mar 19, 2012 | 11:30 PM
vahdyx's Avatar
Is it similar for ss/tc
Old Mar 20, 2012 | 11:18 AM
SaberD's Avatar
LOL $150 for not even 5 minutes of labor? you disconnect 2 hoses and 1 bolt. literally takes 2 minutes. what a scam. you shouldnt need to replace the hoses unless they are leaking.
Old Jun 9, 2012 | 12:26 PM
cobalt3365's Avatar
I am trying to replace this in my 2008 Cobalt LT. I cannot get the solenoid to come off the bracket. I didn't remove the bracket from the engine. Is it necessary to remove the bracket from the engine?
Old Jun 9, 2012 | 04:26 PM
Gelladuga69's Avatar
It's not necessary, but it's easier.
Old Jun 9, 2012 | 05:29 PM
cobalt3365's Avatar
That bolt is a beast. I'll keep trying.
Old Jun 11, 2012 | 05:29 PM
cobalt3365's Avatar
I was able to switch them out. I blew in the old solenoid, and no air passed through, which another website said could be the source of a problem.
Now, I just need to disconnect the negative battery cable to reset the computer. It won't come off.
