How hard is it to change Evap Purge Solenoid?
Old Jun 11, 2012 | 06:33 PM
Gelladuga69's Avatar
Originally Posted by cobalt3365
I was able to switch them out. I blew in the old solenoid, and no air passed through, which another website said could be the source of a problem.
Now, I just need to disconnect the negative battery cable to reset the computer. It won't come off.
Uh, what?
It's a 10mm bolt.
Old Jun 11, 2012 | 06:50 PM
cobalt3365's Avatar
I took the nut off the screw but it won't come up. I'll deal with that tomorrow.
Old Jun 11, 2012 | 06:55 PM
TommyP's Avatar
AWD > FWD
Originally Posted by Tstonee
haha ****. I'll never get a response now b/c everyone will be laughing at my *****.
Probably wouldn't be the first time
Old Jun 12, 2012 | 09:06 AM
cobalt3365's Avatar
Uh, what?
It's a 10mm bolt.
I was able to unhook it. I was afraid to touch the metal.
haha....
Old Jun 12, 2012 | 10:53 AM
haha....
If the car's off, you have nothing to worry about.
Old Jun 14, 2012 | 11:17 AM
cobalt3365's Avatar
Well, I reset the computer on Tuesday. I haven't had an engine light yet. If I make it to Saturday without a light, I'll declare victory.
Old Feb 23, 2013 | 10:49 PM
turbosmart4's Avatar
Mmmm link doesn't work now...
Old Feb 23, 2013 | 10:52 PM
TStone's Avatar
just look at the picture
and cheers to you for searching
Old Feb 24, 2013 | 01:55 AM
Aleksey's Avatar
back from the dead haha, yeah it's really easy to locate and replace, picture is perfect
Old Feb 24, 2013 | 09:14 AM
Old Feb 24, 2013 | 09:16 AM
  #36
What I need is a part number to find it so I can buy it, already tested mine yesterday and I was able to blow some air though it..so its probably goin bad
The link for the part doesn't work
Old Mar 15, 2013 | 04:22 PM
  #37
Jkracka514's Avatar
So what is the blue part outlined in the ***** drawing?
And how do you remove the purge solenoid without removing the bracket it sits on?
Old Apr 8, 2013 | 11:22 PM
  #38
CleanCut's Avatar
How can you tell when this has gone bad? im throwing the p0171 code also and i was seeing that the MAF has a different code so i figure this has to be the problem
Old Feb 22, 2014 | 03:23 PM
  #39
BlackyK's Avatar
Yeah I'm going to have to bump this thread back from the dead again. I've been throwing P0171 for months now and I have been using the Torque app and it says my Evap system is "Incomplete". I have replaced the MAF sensor and all the hose clamps on the intake. Many of the vacuum lines around the purge solenoid are cracked so I think its time to replace all that. Hopefully this finally cures it. Just snooping around for the right sized ID of tubing. And did you guys just buy vinyl tubing from Lowes or find silicone tubing somewhere? I saw the post above about using the 1/4" ID and 3/16" ID with a reducer to the hose "911" in that large diagram.
Old Nov 9, 2015 | 02:15 PM
  #40
nelsonm100's Avatar
On the blue part i have the bottom outlet hose missing and im trying to figure out where is the other hose connector is pls help thanx
Old Nov 9, 2015 | 03:37 PM
  #41
nelsonm100's Avatar
Whats the blue circle part called
Old Nov 15, 2016 | 08:46 AM
  #42
Platinum_Injected's Avatar
I'd also like to know what the blue part is.... my recaro car seems to be missing it altogether... what does it control??? I noticed my boost gauge isn't working, would this do this?? I do know the gauges have a tendency to stop working... already had to replace in my silver car
Old Nov 15, 2016 | 10:31 AM
  #43
Staged07SS's Avatar
Administrator
Administrator
Recaro seats and or G85 did not change anything in terms of the engine...
Not sure why you are missing anything. Did you buy it used?
Old Nov 15, 2016 | 11:10 AM
  #44
yeah was purchased used... not there at all has some vaccum lines blocked off too from the bypass valve
Old Nov 15, 2016 | 06:20 PM
  #45
Wind's Avatar
Take a picture??
Old Nov 16, 2016 | 09:01 AM
  #46
if you scroll up to the "*****" pic it's the blue circled one... my silver car has it lol... but I've had it since it was 2 years old
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
DocSvensk
Sep 27, 2015 02:24 PM
