injector problems
Old Mar 24, 2012 | 03:53 AM
kdog10's Avatar
injector problems
my friend had bought 50# injectors from ZZP. We took the old 42# injectors out and replaced them with the 50. Now when the car is started it reves up from 1000 rpm to 2000 rpm. its also makin a popping sounds that seems to be coming from the injectors. we are not sure whats cuaseing this idle problem since there is no ecu programing needed for the new injectors says ZZP. So in info would be helpful.
Old Mar 24, 2012 | 04:20 PM
2007cobaltsc's Avatar
bump im curious too
Old Mar 24, 2012 | 04:27 PM
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
I would assume a retune would be in order for the 50s.. but zzp said.. Not sure.
Maybe they're not seated correctly?
Old Mar 24, 2012 | 04:28 PM
Dontstoprunning's Avatar
read fine print up top
Old Mar 24, 2012 | 04:30 PM
nhanson's Avatar
you NEED a tune
Old Mar 24, 2012 | 04:46 PM
insylem's Avatar
The "clicking" Is probably the valves in the injectors operating normally. My Simmons 60lb ones do that to some extent.
Old Sep 4, 2012 | 08:40 PM
BoSStwick's Avatar
Mine seems to be doing this too, but when they say your injectors need to be reflashed, doesn't zzp do that when they ask you to send your core in? How important is the dielectric grease and the brake cleaner when installing them? I didn't do either... hope its ok.
Old Sep 5, 2012 | 01:45 AM
Vander Nars's Avatar
Take them out grease them and then u will have peace of mind.
Old Sep 5, 2012 | 10:53 AM
BoSStwick's Avatar
Will that get rid of the check engine light too?
Old Sep 5, 2012 | 03:50 PM
Honestly have no clue, it would mainly depend on what cel u have.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
patooyee
Oct 15, 2015 05:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
