intercooler issues
Old Feb 22, 2021 | 01:28 AM
UVV_PaUl's Avatar
Exclamation intercooler issues
i have a ic on a 2007 cobalt ss lsj and i relized the ic pump went out. i got a zzp ic to replace it but it didnt work and then i checked the fuse it was blown and replaced it and still dosnt work is there anything else that i should check? also how can i tell if a relay is out without having extra ones?
Old Feb 22, 2021 | 02:57 AM
LsCobalt07's Avatar
You could swap the relay with the AC clutch relay, they should be the same style. Test for voltage at the IC pump connector.
Old Feb 27, 2021 | 07:32 PM
UVV_PaUl's Avatar
so I bought a relay tester and the relay was goo so I went and checked the plug to see if it was getting power and the plug wasn’t getting power. Could it be a wire or something that I don’t know about.
FrankieD
Jun 22, 2020 07:01 PM
chrisjaldin
Aug 15, 2012 11:19 PM
thedude411
Aug 1, 2011 08:36 PM
Ljavy17
Jul 25, 2007 11:31 PM
