Lean
not enuff for you to really notice it. I ran my intake plus header/downpipe and exhaust and my car ran fine no lean codes at all. However once you do all those mods then get a tune to get the most hp you possibly can.
you sure that's not coolant you're burning?
well hold on before you start making a mountain out of a mole hill. What other mods do you have? How many miles do you have on your car? I'm assuming you're not tuned, so I'm guessing you must be stock with the exception of the intake? And if it's just a faint amount of smoke, then most likely it's no white (which means you are getting coolant in your engine) and that you have an excess of co2. Which means you are lean and you will throw a CEL soon (p0101 i believe is the code). It's not a big deal, honestly.
yeah, i bet if you have one of the auto zone jerks to read it, they will give you the code that i posted (essentially saying that you're running lean). This is because of two things:
(1) The stock injectors are too small for the car and don't normally deliver a lot of fuel, and;
(2) The aftermarket intake is letting in more air than the stock sized intake. It's throwing off your fuel trims and that's what's setting off the CEL.
I would get a tune if it's bothering you a lot, but honestly it's not a huge deal at the moment, as long as you don't go WOT (which you shouldn't be if you're stock). But if you're gonna consider getting a tune, consider getting some other stuff first to make the most out of it, like bigger injectors and a smaller pulley.
You'll get mixed answers on here. Ideally, no one should ever run lean because it creates a lot of heat and pre-detonation is more likely to occur. My honest opinion: after seeing how much it throws off your long term fuel trims, I say you're okay to drive it as is, so long as you drive it normally and don't go WOT or something stupid. You're car is stock right now: don't think you can start raping sti's or evo's just yet
