Manual Fan Switch?
Old Sep 12, 2006 | 12:32 AM
JonyyB's Avatar
Site Founder
Manual Fan Switch?
I really don’t see manual fan switches being talked about in here so I’ll ask. Anyone install one in a Cobalt? I know fan switches are really popular with f-body cars, especially for track purposes.
The Build Book mentions one, but does not tell you how to hook it up.
Someone needs to make a kit… it would be nice for the track (not that our cars run that hot).
Old Sep 12, 2006 | 12:36 AM
patathSS's Avatar
I have an override mounted under the hood. IT is a jumper wire inline with a toggle switch. I have two of them, one for fans, one for intercooler pump.
Old Sep 12, 2006 | 12:41 AM
cobalt06ss_sc's Avatar
wiring a fan switch shouldn't be that hard. F-Body's ran the extra fans because they had a severe problem with over heating. i have my fan on my IROC wired to run constantly as long as the ignition is turned on and i still ran around 190 degrees and when i turned it off it would blow coolant everywhere. granted i have about 550 hp 383 tpi in it so it creates alot more heat than a normal L98.
Old Sep 12, 2006 | 01:15 AM
kanabrewski's Avatar
diagrams , pinouts, wire colors........how bout a how to......? this is the key many of us need for track use.
Old Sep 12, 2006 | 01:18 AM
patathSS's Avatar
Its been posted a ton already. I have a crude picture in my gallery. All I did was jump the high fan relay and then jump the intercooler pump relay. I use fusible wire.
Old Sep 12, 2006 | 02:16 AM
Cobalt_Supercharged's Avatar
Alright here it is Jonel. It's not exactly a manual switch as it is a complete over ride. https://www.cobaltss.net/forums//showthread.php?t=23151
This can also be done with HP Tuners. That is how PsykoStevo tunes.
Old Sep 12, 2006 | 11:37 AM
patathSS's Avatar
I have my fans set with HPT to run 100% too. But it doesn't help when the car is not running. When I go to the track I get there, flip on my fan and IC pump switch and never turn it off until I leave. The fans and pump run when the car is on or off.
Old Sep 12, 2006 | 11:55 AM
CTCOBALTSSS's Avatar
All of this sounds like people are just overriding and programing with HPTuners.
Can we just hook up a toggle switch in the car and kick the fan whenever?
Old Sep 12, 2006 | 12:01 PM
DWK5150's Avatar
Here is what Im thinking of hooking up with the extra fans for the intercooler I just picked up. I have used these many times beofre on my streetrods and they work very well.
http://store.summitracing.com/partde...5&autoview=sku
Old Sep 18, 2006 | 02:35 PM
ok, here is WoponTOur's mods for either the CAC and FANS with switch or via jumpers and removing the relays.
FAN MOD with 2 relays and Jumper for COOL SER/PAR relay
CAC Intercooler pump mod with relay and switch
Jumper version without switches
PIC 1 of 2
Diagram 2 of 2
direct links for downloading
http://i65.photobucket.com/albums/h2...an20Mod_sm.jpg
http://i65.photobucket.com/albums/h2...CAC20Modsm.jpg
these are the original size. simply remove the space
http://www.re dlineforums.com/forums/attachments/tuning-electronics/3902-how-wire-fan-switch-cobalt-fan-mod_sm.jpg?d=1150696454
http://www.re dlineforums.com/forums/attachments/tuning-electronics/3904-how-wire-fan-switch-cobalt-cac-modsm.jpg?d=1150696516
BTW: metripack #12129497 cost at the dealer is 2.50 usd per piece
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Solaris99
28
Mar 15, 2017 01:22 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Tupp
Sep 30, 2015 08:18 PM
