More Fuel injector help....
Old Aug 2, 2008 | 03:17 AM
HunterKiller89's Avatar
so,...im still trying to get this issue down. I went to the dealer wth a part number, and a VIN, and they could not find a fuel injector harness for my car... so i either need one BADLY from another member, or i need an answer to a question.
#1: What kind of connector is on the 2.2 wiring harness from a 2006 balt... EV1? EV6? a different one? (i think it is neither the EV1 or EV6)
#2: Can I splice the correct injector connection into my wiring harness and have everything be good? The harness looks quite odd, with 6 ends: 1 for each injector, a connector with 2 rows for the input i assume, and a connector with 1 row (3 pins?) at the opposite end...
#3: is there any other solution? perhaps buying injectors that fit the stock harness? I need this done by next saturday at the LASTEST. I already have an appointment with tthe shop, and they cant do anything if I have the wrong injectors...
Old Aug 2, 2008 | 04:36 AM
theneelster's Avatar
All the injector harnesses that people use when swapping are home brew to my knowledge (or sold by companies but made homebrew). You may be able to use the 2.0 harnesses that a bunch of people sell depending on what your upgrading to.
I would be careful doing any splicing and wouldn't recommend it unless it's a dead last option.
I could be wrong but I'm thinking the ev-1 and ev-6 are bosch style injector connections. Are the stock injectors Lucas? They are in the 2.0. If so you can probably upgrade up to the 42lbers that come with stage 2 without swapping harnesses. I don't know, you should CHECK. Am I completely wrong in this assumption?
Old Aug 2, 2008 | 06:47 AM
42lb from stgII dont work, i have a set of 42lbers and the harness that i would use to swap em into a 2.0, but the harness i have has 5 connectors, whereas the stock 2.2l one has 6 connectors
please anyone...i need these parts asap!
any of the 2.2l guys? mkulrey? u have ur old harness from ur turbo build?
Sl0wbaltSS
Nov 21, 2018 11:11 PM
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
roth
Sep 26, 2015 12:16 PM
