Mpg?
Old Nov 7, 2007 | 11:00 AM
  #51
light'bolt's Avatar
Average sez 29.3 on the gage
Old Nov 7, 2007 | 07:40 PM
  #52
Code5's Avatar
Mine was low 29.xx with Stage II. Now 30.0 with Nates 2.90" pulley installed five days ago.
2006 SS/SC, G85
Old Nov 8, 2007 | 09:38 AM
  #53
GhostX's Avatar
Mine shows around 26 on the DIC.
Old Nov 8, 2007 | 09:47 AM
  #54
Edubs's Avatar
32 average, I see around 38 on the highway with steady elevation. 36.5 on the thruway between Albany & Syracuse...
Old Nov 8, 2007 | 04:35 PM
  #55
cobaltguy88's Avatar
I got 26.4 MPG on the city on an 8 mile drive to school... Bet i can get more once my K&N intake breaks in and the computer adjusts to the new intake
Old Nov 8, 2007 | 07:50 PM
  #56
YSUsteven's Avatar
An intake doesn't "break in". It doesn't have any moving parts.
I hope you actually get better milage.
Old Nov 9, 2007 | 12:26 AM
  #57
roccityroller's Avatar
I'm pretty sure its from the computer learning the new air readings and handling it better.
Old Nov 9, 2007 | 09:36 AM
  #58
OniMirage's Avatar
filled up yesterday and decided to take it easy since gas is 3.20 right now ... currently at 29.4 mpg after going home then coming back to work roughly 50-55 miles round trip
Old Nov 9, 2007 | 09:41 AM
  #59
sharky_9901's Avatar
I have only filled my tank once, but on my first tank i averaged 27 mpg. Mostly city driving but there was about 90 miles of highway too.
Old Nov 9, 2007 | 09:53 AM
  #60
OniMirage's Avatar
you are correct. since the ecu determines how much fuel to add for the temperature and rate the air is coming in as it is passing the maf sensor there is a 'break in' type period where the ecu is determining the correct values to allow the car to drive smoothly. I don't know the exact value but there is a range where the computer will operate within to keep the car stable and adding an intake will allow the car to run in a closer to optimal range ... sometimes the car can't reach that level and you get a lean code so then you have to tune the car to allow for your new abilities from the intake.
Old Nov 9, 2007 | 09:58 AM
  #61
EmperorJJ1's Avatar
i drive liek a crazy maniac... ~20mpg
dieGone
Sep 23, 2015 10:20 AM
Dark-Fx
Sep 7, 2006 08:30 PM
Xenozx
Nov 16, 2005 10:26 AM
DD_Drummer44
Oct 26, 2005 12:02 AM
Darksun
Aug 10, 2005 12:43 AM
