My 2006 cobalt ss has an unknown tune an it misfires over half throttle or 20kpa boos
Old Apr 22, 2019 | 01:45 PM
Zackmanuel88's Avatar
Hey guys i have a supercharged cobalt with the 2.0 engine in it. I bought it off someone and it misfires when i step on it over half throttle or if the boost goes over 20kpa. I just put 4 new plugs in them and when i tried it out the misfire was gone and i took off like a jet down the road. But after i stopped and took off again it gave to much fuel or air again and fouled the brand new plugs right away. Does anyone know what i should try next? Thanks in advance!
Old Apr 22, 2019 | 02:09 PM
Sharkey's Avatar
what plugs did you put in it? what did you gap them at?
what mods are done to the car? what size blower pulley?
Old Apr 23, 2019 | 08:47 AM
jdbaugh1's Avatar
^^ The above questions plus I am guessing your CEL light is on and if so what all trouble codes are set?
Old Jun 5, 2019 | 02:30 PM
steelmesh's Avatar
If you're running super rich, then it might be something with the tunes fuel calibration or you have a mechanical problem that caused the tune to become rich. You'll need to see what your AFR is doing with a wideband air fuel meter to see if you need to make adjustments. For now you'll need to check for mechanical problems between the air filter and muffler.
Zackmanuel88
Apr 22, 2019 01:53 PM
horsinround1974s
Oct 23, 2015 07:41 PM
mscobaltss
Sep 23, 2011 03:36 PM
aaron1218
North Central
Apr 12, 2010 06:08 PM
