is my intercooler bad?
woah, I was unaware the intercooler on the cobalt SS needed fluid to work properly, Im going to go pour coolant into my intercooler, BRB!
Edit: didnt see a fill cap so I just poured it through the intake. Car stumbled pretty bad at first on start up but over all I think it sounds much better.
i was looking up the inter cooler pumps because mine is bad i found a bosch inter cooler pump that seems like it would work. Is this a good choice or has anyone had better luck with a different one?
Bosch - LSJ Replacement IC Pump #BSH-0392022002
here is a link to the pump u need and any kinda of upgrade pump would require custom installing also this is the same pump that is used for the 400+ hp 03/04 supercharged mustangs so it will flow all u need anyways.
Iceberg
Sep 29, 2015 12:33 PM
