NEED GM Tech Or SS/SC Owner Help!
Old Feb 2, 2007 | 12:39 PM
mkulrey13's Avatar
Before i buy the retainers for my ss/sc bumper i would like to double check to see if this (22688427) is all i need to connect the ss/sc lip to my ss/sc bumper. anyone can get pics on how it connects or anything also would be a great help. thanks
Old Feb 2, 2007 | 12:42 PM
Dman's Avatar
That is the part number for a retainer for the rear lip.
Old Feb 2, 2007 | 01:10 PM
kenhebe's Avatar
I manage a paint and body shop and have all the information for you. DO NOT LISTEN TO ANYBODY ELSE.
Here is what you will need to make the lip attatch to the bumper
(1) Lower Bracket nut (11515842) 4.12 each (4 reccomended)
(2) RT Lower Bracket (15248110) 64.66
(3) LT Lower Bracket (15248111) 64.66
(4) Lower Bracket screw (11609406) 0.62 each (4 reccomended)
(5) Lower deflector retainer (10134407) 0.72 each (10 reccomended)
(6) Lower deflector retainer nut (22688427) 4.19 each no listing on what is required.
The part number you provided is the same for the rear bumper cover because they use the same hardware for the front and the rear.
Check with you rlocal dealer to see exactly how many you will need.
Hope this helps you out.
Old Feb 2, 2007 | 02:10 PM
red_wing_2121's Avatar
Illustration Text for # 1 - 2005-2007 AP37 BUMPER/FRONT
Art: 1A07-012 - Callouts: 34, Service Kits: 1
GM PART GROUP DESCRIPTION LIST
001 15232755 07.874 BRACKET,FRT BPR FASCIA (7.869) 6.66
001 15232755 07.869 BRACKET,FRT BPR FASCIA 6.66
001 15232754 07.874 BRACKET,FRT BPR FASCIA (7.869) 6.66
001 15232754 07.869 BRACKET,FRT BPR FASCIA 6.66
002 11609268 08.900 BOLT-HEX W/FLAT WASHER,M6X1X25,23,17 OD,6202M STL,GMW3200, TAP (FRT BPR FASCIA OTR RET) 4.25
003 22692397 07.869 BRACKET,FRT BPR IMP BAR 4.63
003 22692396 07.869 BRACKET,FRT BPR IMP BAR 4.55
004 NS BRACKET,FRT BPR IMP BAR (PART OF 26)
005 NS BAR,FRT BPR IMP (PART OF 26)
006 25631448 07.874 BOLT,FRT BPR FASCIA ENGY ABS (7.831) 1.12
007 15214862 07.840 ABSORBER,FRT BPR FASCIA ENGY 55.44
008 19120184 07.831 FASCIA,FRT BPR (INCLS 17) (PAINT TO MATCH) 350.64
009 11515638 08.921 NUT,U-TYPE, M4.2X1.41X10.5.5X22,.65-3.8 PNL THK,1050,ZF (FRT BPR FASCIA) 0.56
010 15248111 07.831 BRACKET,FRT BPR FASCIA OTR (INCLS 12) 69.83
010 15248110 07.831 BRACKET,FRT BPR FASCIA OTR (INCLS 12) 69.83
011 11609406 08.977 SCREW,RD,M4.2X1.41X20, TYPE AB PT, GM6010M, GMW4205 (FRT BPR FASCIA OTR BRKT) 0.62
012 11515842 08.921 NUT, U STYLE,4.2X1.41,PNL THK 3.0 - 3.0MM,GM7111M (PART OF 10) 4.12
013 22688427 07.831 RETAINER,FRT BPR FASCIA EXTN 4.19
014 12336084 07.831 EXTENSION,FRT BPR FASCIA 234.39
015 10134407 07.831 RETAINER,FRT BPR FASCIA (PUSH IN) (EBONY) (18.8X6.3X20.4MM) (NYLON) (ROUND) (1.272) 0.72
016 25631448 07.831 RETAINER,FRT BPR FASCIA (PUSH IN) 1.12
017 10134407 07.831 RETAINER,FRT BPR FASCIA (PUSH ON) (PART OF 8) (EBONY) (18.8X6.3X20.4MM) (NYLON) (ROUND) (1.272) 0.72
018 09423101 08.977 SCREW,TAP,M6.3X1.81X16,14.55 O.D.,7114M,PZ0R (FRT LIC PLT) (*KIT1) 1.31
019 15253233 07.800 BRACKET,FRT LIC PLT 10.25
020 15252974 01.303 EMBLEM,RAD GRL 15.30
021 11561338 08.900 BOLT SHLDR, M6X1X22 (FRT BPR FASCIA OTR RET) 4.25
022 11561838 01.303 NUT,RAD GRL EMB 3.50
023 22728455 07.831 BUMPER,FRT BPR FASCIA (OVERSLAM BPR) 3.63
024 05973400 01.269 RETAINER,RAD GRL (BLACK) (22.5MM) (ROUND) 1.22
025 11515756 08.900 BOLT,HFH, M8X1.25X20,17THD,18 O.D.,10.9,7114M (PART OF 26) 0.63
026 22695228 07.831 BAR,FRT BPR IMP (INCLS 4,5,25) (W/BRACKETS) 101.13
027 22638717 07.800 RIVET,FRT LIC PLT BRKT (4.85MM DIA) (*KIT1) 0.70
028 15261797 07.831 BRACKET,FRT BPR FASCIA UPR OTR 5.27
028 15261796 07.831 BRACKET,FRT BPR FASCIA UPR OTR 5.27
Service Kits
001 22714456 07.800 ATTACHMENT KIT,FRT LIC PLT (INCLS 18,27) 8.57
COOLING SYSTEM-GRILLE-OIL SYSTEM
01.269: Radiator Grille and Front End Panel
05973400 A RETAINER,RAD GRL (BLACK) (22.5MM) (ROUND) (01.269) 04 1.22
01.303: Radiator Grille and Front End Ornamentation
15252974 AP37 EMBLEM,RAD GRL (01.303) 01 15.30
11561838 AP37 NUT,RAD GRL EMB (01.303) 02 3.50
FRAMES-SPRINGS-SHOCKS-BUMPERS
07.800: License Plate
22714456 A FRT LIC PLT MTG PKG (VK3) ATTACHMENT KIT,FRT LIC PLT (07.800) 01 8.57
15253233 A FRT LIC PLT MTG PKG (VK3) BRACKET,FRT LIC PLT (07.800) 01 10.25
22638717 A FRT LIC PLT MTG PKG (VK3) RIVET,FRT LIC PLT BRKT (4.85MM DIA) (07.800) 03 0.70
07.831: Bumper/Fascia Face
22695228 A BAR,FRT BPR IMP (W/BRACKETS) (07.831) 01 101.13
15248111 A BRACKET,FRT BPR FASCIA OTR (07.831) - LH 01 69.83
15261796 A BRACKET,FRT BPR FASCIA UPR OTR (07.831) - RH 01 5.27
15261797 A BRACKET,FRT BPR FASCIA UPR OTR (07.831) - LH 01 5.27
15248110 A BRACKET,FRT BPR FASCIA OTR (07.831) - RH 01 69.83
22728455 A BUMPER,FRT BPR FASCIA (OVERSLAM BPR) (07.831) 02 3.63
12336084 AP EXTENSION,FRT BPR FASCIA (07.831) 01 234.39
19120184 AP37 FASCIA,FRT BPR (PAINT TO MATCH) (07.831) 01 350.64
22688427 AP RETAINER,FRT BPR FASCIA EXTN (07.831) 12 4.19
10134407 AP37 RETAINER,FRT BPR FASCIA (PUSH IN) (EBONY) (18.8X6.3X20.4MM) (NYLON) (ROUND) (1.272) 02 0.72
25631448 AP,AM RETAINER,FRT BPR FASCIA (PUSH IN) 04 1.12
10134407 A RETAINER,FRT BPR FASCIA (PUSH ON) (EBONY) (18.8X6.3X20.4MM) (NYLON) (ROUND) (01.272) 02 0.72
07.840: Bumper/Fascia Energy Absorber
15214862 A ABSORBER,FRT BPR FASCIA ENGY (07.840) 01 55.44
07.869: Bumper/Fascia Mounting
15232755 A BRACKET,FRT BPR FASCIA (07.869) - RH 01 6.66
15232754 A BRACKET,FRT BPR FASCIA (07.869) - LH 01 6.66
22692397 A BRACKET,FRT BPR IMP BAR (07.869) - LH 01 4.63
22692396 A BRACKET,FRT BPR IMP BAR (07.869) - RH 01 4.55
07.874: Bumper/Fascia Mounting
25631448 A BOLT,FRT BPR FASCIA ENGY ABS (07.831) 02 1.12
Illustration Text for # 2 - 2005-2007 AP37 BUMPER/REAR
Art: 1A07-015 - Callouts: 27
001 15854464 07.831 BAR,RR BPR IMP 104.68
002 22695268 07.840 ABSORBER,RR BPR FASCIA ENGY 91.65
003 20733729 08.927 WASHER,SEALING,M5, 4 I.D.,25MM O.D., 4MM THK,RUB (RR BPR FASCIA BRKT) 1.49
004 15220077 07.831 BRACKET,RR BPR FASCIA 29.65
005 11517293 08.917 NUT,HEX W/CON WA,M6X1,5.7THK,16 O.D.,9,6280M (RR BPR FASCIA BRKT) 0.57
006 12336078 07.831 FASCIA,RR BPR UPR 352.08
007 11515196 08.900 SCREW,RND WA HD,M4.2X1.41X16,HILO SELF- TAP,8.2 O.D.,6010M,NO (RR BPR FASCIA) 1.23
008 20664092 07.831 RETAINER,RR BPR FASCIA (PUSH IN) (BLACK) (6.3MM DIA X 23MM) (1.276) 0.69
009 05973400 07.831 RETAINER,RR BPR FASCIA (PUSH IN) (BLACK) (22.5MM) (ROUND) (1.269) 1.22
010 03907444 08.921 NUT,PUSH IN,SQUARE,UN THD,M9.5 SQ HOLE,NYLON (LIC PLT) 1.31
011 09423101 08.977 SCREW,TAP,M6.3X1.81X16,14.55 O.D.,7114M,PZ0R (LIC PLT) 1.31
012 12336082 07.831 EXTENSION,RR BPR FASCIA 250.00
013 89025744 07.831 GRILLE,RR BPR FASCIA EXTN 55.61
014 89025745 07.831 GRILLE,RR BPR FASCIA EXTN 32.20
015 22688427 07.831 RETAINER,RR BPR FASCIA EXTN 4.19
016 11504678 08.977 SCREW,LG RD HD TORX TAP M4.2X1.41X20 SS BL OX (RR BPR FASCIA EXTN) N.A.
017 11515842 08.921 NUT, U STYLE,4.2X1.41,PNL THK 3.0 - 3.0MM,GM7111M (RR BPR FASCIA EXTN RET) 4.12
018 11609489 08.977 BOLT-HEX W/ WASHER,4.2X1.41X25,14.5 THD17 OD,GM6010M STL, GMW4205 (RR BPR FASCIA) 0.69
019 15249722 07.831 BRACKET,RR BPR FASCIA (UPR BRKT - ATTACH TO QTR PNL) (LH) 14.35
019 15249721 07.831 BRACKET,RR BPR FASCIA (UPR BRKT - ATTACH TO QTR PNL) (RH) 14.35
020 25536302 07.831 NUT,RR BPR FASCIA BRKT (4.2X1.41 TAPPING) (.71 THK) (3.430) 4.47
020 11569711 07.831 NUT,RR BPR FASCIA BRKT (M4.2X1.41) (0.7-2.15 PNL THK) (9.667) 3.51
021 15277669 07.831 BRACKET,RR BPR FASCIA (SI BRKT - ATTACH TO QTR PNL) (LH) 9.85
021 15277668 07.831 BRACKET,RR BPR FASCIA (SI BRKT - ATTACH TO QTR PNL) (RH) 9.85
022 22549046 08.977 SCREW,M4.2X1.4X25,11.1 O.D.,6010M,NZ (RR BPR FASCIA OTR RET) 0.63
023 11519387 08.900 BOLT-HWASH,M8X1.25X20,14 THD,24 OD,GMW25 (8.8)STEEL,GMW3359,M-POINT. (RR BPR IMP BAR) 4.04
024 11561097 07.831 RETAINER,RR BPR FASCIA LWR (GRILLE) 3.46
Part Usage Text
15854464 A BAR,RR BPR IMP (07.831) 01 104.68
15220077 A37 BRACKET,RR BPR FASCIA 01 29.65
15249721 A37 BRACKET,RR BPR FASCIA (UPR BRKT - ATTACH TO QTR PNL) (RH) 01 14.35
15249722 A37 BRACKET,RR BPR FASCIA (UPR BRKT - ATTACH TO QTR PNL) (LH) 01 14.35
15277669 A37 BRACKET,RR BPR FASCIA (SI BRKT - ATTACH TO QTR PNL) (LH) 01 9.85
15277668 A37 BRACKET,RR BPR FASCIA (SI BRKT - ATTACH TO QTR PNL) (RH) 01 9.85
12336082 AP37 EXTENSION,RR BPR FASCIA (07.831) 01 250.00
12336078 AP FASCIA,RR BPR UPR (07.831) 01 352.08
89025744 AP GRILLE,RR BPR FASCIA EXTN (07.831) - RH 01 55.61
89025745 AP GRILLE,RR BPR FASCIA EXTN (07.831) - LH 01 32.20
25536302 A37 NUT,RR BPR FASCIA BRKT (4.2X1.41 TAPPING) (.71 THK) (03.430) AR 4.47
11569711 A37 NUT,RR BPR FASCIA BRKT (M4.2X1.41) (0.7-2.15 PNL THK) (09.667) 08 3.51
22688427 AP RETAINER,RR BPR FASCIA EXTN (07.831) 14 4.19
20664092 A RETAINER,RR BPR FASCIA (PUSH IN) (BLACK) (6.3MM DIA X 23MM) (1.276) 04 0.69
05973400 A RETAINER,RR BPR FASCIA (PUSH IN) (BLACK) (22.5MM) (ROUND) (1.269) 04 1.22
11561097 AP37 RETAINER,RR BPR FASCIA LWR (GRILLE) (07.831) 04 3.46
22695268 AP ABSORBER,RR BPR FASCIA ENGY (07.840) 01 91.65
Confusing, but it is all parts for '07 Cobalt SS/SC fascias
Old Feb 2, 2007 | 04:30 PM
fr33k's Avatar
ya forgot to give the pics so they know what the callouts mean.
ART: 1A07-012 Front fascia
ART 1A07-015 Rear fascia
Old Feb 2, 2007 | 06:06 PM
mkulrey13's Avatar
wow thanks guy this is going to put a dent in the CC jsut to attach the damn thing. so much for my rear ss bumper
Old Feb 2, 2007 | 06:37 PM
Thanks man! Should have thought of that.
Old Feb 2, 2007 | 06:40 PM
potatoe's Avatar
Are you trying to put a SC bumper on a non SC... cause the SC bumper has slots for clips all along the bottom of the bumper. Non SC dont hace these slots. -Nathan
Old Feb 2, 2007 | 06:41 PM
mkulrey13's Avatar
Um no...i have the ss/sc bumper and the lip just need to have the hardware to attach it. i know what im doing... im not twisted here come on now...
Old Feb 2, 2007 | 06:56 PM
potatoe's Avatar
OOh ok sorry man.. I think theres 11 or 12 spring clips and 4 screws if i recall right. -Nathan
Old Feb 3, 2007 | 08:29 AM
denniss's Avatar
You don't want my clips? Check your previous post. I will send you 11 for the cost of shipping, roughly the price of 1 from the dealer. They are #13 in the picture in this post.
Dennis
Old Apr 24, 2008 | 07:16 PM
SSBolt24V's Avatar
will the sc lip fit on a 2.4 bumper? It looks to be the same bumper w/o the lip.........
Old Apr 26, 2008 | 01:44 PM
mkulrey13's Avatar
No please search......
Old Feb 9, 2010 | 12:47 AM
mrdubord's Avatar
plzzzz will someone tell me what the piece is that attaches the front bumper to the fender. and if so does anyone have a part number or a place where i might be able to get it
Old Feb 9, 2010 | 07:34 PM
INDColtsFan18's Avatar
thank you for this thread, helped a ton
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
Oct 20, 2015 09:56 PM
justinchinn
Oct 2, 2015 12:18 PM
