oil catch can location?
Old Mar 14, 2015 | 06:07 PM
DevZX's Avatar
hey guys i have the jegs air/oil separator and from what i found from searching in this forum im seeing mixed reviews of it being mounted behind the valve cover to the hose that goes to the CAI pipe. when i cleaned my throttle body i found no oil in the tube only in the supercharger area.. is there another location where it should be installed?
Old Mar 24, 2015 | 08:02 AM
DevZX's Avatar
anyone?
Old Mar 24, 2015 | 09:24 AM
yellowsupercharged06's Avatar
there is an ongoing discussion about the correct way to set one of these systems up but I can not give you the answer myself lol.
Powell makes a separator system that the LNF guys use and it seems to have great reviews, but as for a low cost LSJ setup i am not sure ... maybe one of the more knowledgeable guys can chime in.
where are you on the island btw ?
Old Mar 24, 2015 | 11:29 PM
DevZX's Avatar
Old Mar 24, 2015 | 11:31 PM
DevZX's Avatar
yeah ive seen many discussions on it about putting it behind the valve cover and then people saying it wont work in that spot.. lol. i already have the jegs can i might just try putting it behind the valve cover and see what happends.. im from West Hempstead what about you man?
Old Mar 24, 2015 | 11:37 PM
Powell makes one for the LSJ also.
Old Mar 25, 2015 | 09:07 AM
im in Farmingdale.
the what is the difference between the lsj and lnf one he makes ? im pretty sure they are pretty similar to each other and cost is right about the same.
Old Mar 25, 2015 | 09:30 AM
Its just line differences, they connect in different locations iirc. I believe he uses the same separator including the return line
Old Mar 25, 2015 | 09:44 AM
yeah thats what i thought.
but the jegs thing is just a catch can if i recall correctly Powell has a drain back line from the seporator that drains back into the special dip stick tube.
Old Mar 25, 2015 | 09:54 AM
I think the jegs thing is a oil separator from an air compressor that requires you to manually empty it. Not sure the pressure drop across it buy I know the unit Powell uses does not have significant pressure drop as its actually engineered for the application used and a lot of direct injector diesel guys use it.
Old Mar 25, 2015 | 07:30 PM
DevZX's Avatar
Yeah the jegs is basically an air/oil separator for a air compressor. you have to manually drain it from the bottom. not really sure on the pressure drop.. where can i find this Powell can? i cant seem to find it on google.. wow your 20 minutes away from me lol.
Old Mar 25, 2015 | 08:27 PM
heeter_33's Avatar
Powellraceshop.com
His website isn't the best, but his parts are. Usually just have to email.
Also lots of info in here.
https://www.cobaltss.net/forums/gene...powell-296456/
Old Mar 26, 2015 | 09:43 AM
yeah just need to hook it up the correct way thats all.
yeah im pretty close to ya .. if you ever need HPT for tuning or w.e i have it so just let me know.
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
Trav3480
Oct 1, 2015 08:17 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
