question on cams?
You would certainly want upgraded valve springs and retainers as a minimum.....neutral balance shafts are a good idea depending what cams and rpm you want to rev to. Hp depends on which cams, supporting mods, tune, fuel choice etc. A set up with required parts at new prices would probably run around 1200ish plus install and a tune. If you are worried about money, i would look for other things to do
Sl0wbaltSS
Nov 21, 2018 11:11 PM
