Smallest Pullie
Old Feb 20, 2007 | 01:58 AM
Super_SS's Avatar
Smallest Pullie
Ajt ladies and pimps....lol...im not a expert when it comes to the cobalt motor...learned everything on the srt4 motor,so the Supercharger is TOTALLY new to me...my question
What is the smallest pully i can run on the stock injectors and everything else stock besides the pully...i will be upgrading to a s2 gm,but that will be around june-july..want to be reliable and also safe for daily driving
Old Feb 20, 2007 | 02:01 AM
Cobalt_Supercharged's Avatar
There are some people running 3.00" but honestly the stock injectors are prety much maxed out with the stock 3.35" pulley. I would wait till you get the GM Stage injectors before you change the pulley out.
Old Feb 20, 2007 | 02:04 AM
Spectral's Avatar
wait till you get stage 2.
Old Feb 20, 2007 | 03:06 AM
Red2.4SS/SC's Avatar
if your at sea level i would wait if your at high elevation ive heard of people running 3.1 pulleys
Old Feb 20, 2007 | 03:39 AM
bigtemps's Avatar
If i could add to this question then, because im looking at getting a cobalt with stage 2.
the stage 2 pulley is only 3.0in. is it possible to go lower than that, say 2.8in pulley without upgrading the injectors. and if the injectors are fine with the 2.8in pulley will it need to be tuned more, or is the stage 2 tune enough.
Old Feb 20, 2007 | 03:45 AM
ive said it countless times , but ill say it again since your new , stage 2 injectors are not fine with a 2.8 pulley you need 60 lb injectors with a 2.8 pulley, and no the stage 2 tune is not enough you will need a custom tune
the lowest i would go is a 2.9 and thats pushing it pretty good in my book the stage 2 tune should be ok with it but im not positive on that , im running stage 2 pulley with lucas 42lb injectors not the stage 2 injectors with gm stage 2 tune and if i swap pulley im changing the tune no matter what
Last edited by Red2.4SS/SC; Feb 20, 2007 at 03:45 AM. Reason: Automerged Doublepost
Old Feb 20, 2007 | 01:20 PM
leviticus88's Avatar
And I will say it again! Elevation plays a huge part in this too! Im running stage 2 + 2.8 pulley at over a mile high! I only see 14-15 psi and my injector duty cycles are fine.
It really all depends on where you are and your car/mods.
Badmunky
Apr 24, 2006 02:01 AM
venum_us_2002
Mar 16, 2006 09:42 PM
Blue04RedLine
Jan 10, 2006 11:37 AM
1MEANSS
Dec 19, 2005 01:02 AM
Darksun
Nov 2, 2005 09:41 AM
