ss/sc intercooler
Old Feb 1, 2009 | 08:03 PM
  #51
daythecountrydied21's Avatar
Originally Posted by 1badBlueberrySC
^^lolz^^
Why are you lol'ing? We forever have this
We don't have an intercooler... we have a Heat Exchanger
Here's a video incase you're a visual learner...
Old Feb 1, 2009 | 08:04 PM
  #52
1badBlueberrySC's Avatar
I don't see what you are arguing about here?
If you want to be technical it's an AFTERCOOLER...
Old Feb 1, 2009 | 08:08 PM
  #53
blackbird's Avatar
No, the heat exchanger is not an "intercooler". It's technically just a radiator and is part of the intercooler system (the liquid-to-air setup). If you want to get technical the actual intercooler cores are the Laminovas in the intake manifold.
Old Feb 1, 2009 | 08:09 PM
  #54
Don't fuel him... he's too dense to realize that it has a completely different function than the air to air intercooler!
Old Feb 1, 2009 | 08:11 PM
  #55
I never said it didn't, fact is its still called an air to liquid intercooling system....
Old Feb 1, 2009 | 08:14 PM
  #56
blk ss/sc 1's Avatar
x2.. everyone thinks you need a turbo for it to actually be called a reall intercooler.. its just a differnt type.. if you dont believe me .. then like i said please call or e-mail any intercooler manufacturer and ask them
Old Feb 1, 2009 | 08:15 PM
  #57
Bl4des's Avatar
y are you arguing about what the system is called we are not talking about that the fact is the heat exchanger IS NOT AN INTERCOOLER
Old Feb 1, 2009 | 08:22 PM
  #58
ok well not gonna argue with people who can't comprehend..
hm talking about heat exchangers?
ok. well if you're looking to upgrade that to the top of the line cooling system you will want to strongly disregard what was said above. granted this solution is by far one of the most expensive, it is the best solution.
this would be the griffin dual pass h/e. replaces stock unit and is more effiecent than many of the cheaper h/e's that people are running dually in line with the stock.
so do you wanna spend money or get the very best? or settle for a little less?
qwikredline is one of the few i know to be using it, and most info is derived from him.
it is the same unit that gm uses to upgrade their performance versions of cars.
Old Feb 1, 2009 | 08:24 PM
  #59
You gonna go there with efficiency... what do you have that proves that.
What changes in IAT2*'s do you have to prove that Griffin STOCK location H/E is better than say a large core front mount H/E?
I have 100's of logs to prove what my IAT's are... do you... or what proof do you have that it's better?
Or are you just a name nutswinger?
Old Feb 1, 2009 | 08:38 PM
  #60
I don't have it on mine, I'm not pushing my car to the brink and when I do it will be a vrooom psh not a wheeeeeeeeeeeeeeeeeeeee. .
Like above mentioned, qwikredline has it.
he's one of the people who helps build the time attack cars.
I think it's safe to say that he knows his ****.
Haven't seen any of his logs but I gurantee you they're better than most if not all other h/e's
Old Feb 1, 2009 | 08:39 PM
  #61
I know John and he knows his ****, kthxbai
Old Feb 1, 2009 | 10:32 PM
  #62
rukkee's Avatar
What the S/C sits on is called an intake manifold... I fail to see your logic.
It would be an Air to Water Heat Exchanger...
Yeah an intake manifold with a air to water intercooler. The heat exchanger on our car's is only 1 of many parts of our intercooling system.
Whoever called it an Aftercooler is right , but now a days the word intercooler has taken over and can and is used to describe both.
Copied and pasted:
An INTERCOOLER is what is used on setups with multiple stages of forced induction-just like tractor pullers who may be running two turbos on one engine (one spooling up at lower RPM's than the other). The INTERCOOLER cools the charge "INBETWEEN" (Hence the prefix "inter") the two turbos/superchargers-if their centrifugal of course and not positive displacement. On the other hand, an AFTERCOOLER is the correct name for a device that cools the charge between the discharge of the blower and the inlet of the throttle body. Paxton, Powerdyne, Procharger, Kenne Bell, Saleen etc, etc, all make such devices as we know. Just wanted to clarify this because so many people use INTERCOOLER in an incorrect way even though it has become the "norm".
Old Feb 1, 2009 | 10:46 PM
  #63
dperkins1988's Avatar
running 2 coolers is the way to go I have been happy with mine!
Old Feb 2, 2009 | 12:39 AM
  #64
lsjwannabe's Avatar
Originally Posted by Bl4des
the zzp is only 190 plus shipping
and ott is 240
ZZP has a smaller core unit and doesn't include stainless accessories and slighlty less hose then us
Old Feb 2, 2009 | 01:05 AM
  #65
EatonTVS07's Avatar
intense arguement lol
Old Feb 2, 2009 | 11:50 AM
  #66
ShortStack's Avatar
Yes it is worth it... the size difference is what makes it worth it!
Heat Exchanger = Intercooler...
It is either a Air to Air intercooler, or a Air to Water intercooler.
A heat exchanger is a general term used for something that displaces heat due through a type of "exchanger".
Technically, a air to air (turbo) exchanges heat using air. Our system exchanges heat using water.
They ARE the same thing.
Old Feb 2, 2009 | 11:51 AM
  #67
Short did you get my pm about the hpt?
Old Feb 2, 2009 | 12:52 PM
  #68
LSJAY's Avatar
What exactly does the GM dual pass end plate do?
Old Feb 2, 2009 | 01:03 PM
  #69
I will refer you to a post on RLF once I can find it, will explain everything better than I could with words.
here it is, credit to ebristol for post .
Originally Posted by ebristol
Here is how a standard Heat Exchanger works:
Here is how a Dual Pass Heat Exchanger works:
Here is how a Six Pass Heat Exchanger works:
The stock IM works like this:
A dual pass endplate works like this:
A single pass would work like this:
So for the Intake manifold the lower number of passes is better.
For the Heat Exchanger the higher number of passes is better.
Old Feb 2, 2009 | 01:14 PM
  #70
EatonTVS07's Avatar
so does this intern mean a radiator is a intercooler?
Old Feb 2, 2009 | 01:16 PM
  #71
radiator cools the enigne bud
Old Feb 2, 2009 | 01:25 PM
  #72
EatonTVS07's Avatar
i knoe but doesnt the heat exchanger help cool down the coolant that enters through the laminovas in the intake manifold? kinda the same principal as a raiator right?
i'm not trying to be a smart ass or anything, i'm just using this as a learning experience and trying to get my facts straight
Old Feb 2, 2009 | 01:28 PM
  #73
cakeeater's Avatar
the new OTT H/E is the biggest one yet
yea same principal, technically speasking though its an aftercooler cause it comes after the blower
no. aftercooler is a term used by vortech for their intercoolers. An intercooler doesn't come before the turbo/blower either, it comes after. You guys have an air/liquid intercooler.
Old Feb 2, 2009 | 01:38 PM
  #74
blackbird's Avatar
By definition a radiator is "any of various devices (as a series of pipes or tubes) for transferring heat from a fluid within to an area or object outside". You have a radiator that transfers heat from the engine's cooling system to the ambient air and you also have a radiator (i.e. the heat exchanger) that transfers heat from the liquid-to-air coolant to the ambient air. And by definition an air-to-air intercooler is also a radiator that transfer air from the fluid (which can be a gas) to the external ambient air.
This thread seems to be spiraling down a path of arguing over definitions and it's possible to apply more than one definition or term to certain components in the LSJ's intercooling system. The term "intercooler" or "aftercooler" could be used to describe the whole system of components that comprise the charge air cooling. If you want to break it down further, the Laminova cores in the intake manifold are the air-to-liquid intercooler cores, which might fit the service description of a heat exchanger but generally are not called that in this application. The front mounted heat exchanger that transfers the heat collected from the Lamniovas to the ambient air passing over the heat exchanger core is generally called a heat exchanger but you wouldn't be wrong in calling it a radiator. Some cars also have radiators for oil-to-air cooling, differential fluid radiators, and even power steering radiators (though in those applications it may more commonly be called a "cooler": same difference).
The biggest thing is understanding how the system works and being able to convey what you're talking about to others. A few people are calling components like the heat exchanger a different name but we're able to put it in context and understand what is being discussed. When you use a term that isn't generally interchangeable (like calling the Laminova cores the heat exchanger or the front mount heat exchanger/radiator the intercooler) it brings about confusion in trying to figure out what part is being talked about.
See above post #62. That is really close to the generally accepted industry descriptions that have dated back decades.
Old Feb 2, 2009 | 01:44 PM
  #75
EatonTVS07's Avatar
good explanation blackbird thanks
