Thumping noise?
Thumping noise?
So the other day i was driving, going from a stop i start to go. First gear is engaged then i floor it, when i floored it the car made this loud dun dun dun noise. Is it just wheel spin? or is it just driver error?
It can **** up your trani and drive shafts
Trani mount bushings and a ingalls stiffy or solid motor mount will help stop wheel hop
wow i had no idea, no more throttle in first.
does that always happen when you give it throttle?
Last edited by cobaltSS2.4liter; Feb 24, 2008 at 09:52 PM. Reason: Automerged Doublepost
if the clutch is all the way in you get no drag on the transmission and go nowhere. Now if you let the clutch all the way out you should be fully engaged. So if you let the clutch out slower you will feel the clutch dragging or you are what is called feathering he clutch. Essentially you are not allowing he car to have full power to the transmission all at once. It produces a little more heat but it saves the axels if you wheel hop a lot.
DANRICKARD
Oct 1, 2015 12:08 AM
