torque
Old Dec 4, 2009 | 02:26 AM
kush's Avatar
torque
What's the torque for the 2.4L LE5 Oil filter housing cap? Is it different for each model? I've seen different answers from looking around
Old Dec 4, 2009 | 03:30 PM
jmz250's Avatar
Just twist it 'til it's tight. As long as you don't just hand tighten it you'll be fine.
Old Dec 4, 2009 | 04:04 PM
1niceLS's Avatar
X2 ^^^^^^
Old Dec 4, 2009 | 04:09 PM
oopsitouchedmyself's Avatar
snug it up is a better way of putting it...
Old Dec 4, 2009 | 04:11 PM
Black SS/SC 06's Avatar
That has always worked for me.
Except for once on an engine mount bolt
Old Dec 4, 2009 | 04:15 PM
1niceLS's Avatar
Sorry to thread jack but what happened? I m curious because I have to install my TTR Mount and it says torque to spec and I just figured if I tightened it as tight as I could it would be fine.
Old Dec 4, 2009 | 04:16 PM
Just over tightened it and the head popped off
Old Dec 5, 2009 | 01:06 PM
jmz250's Avatar
Yeah I kinda draw the line there. If it's something that's actually important (Caliper bracket mount bolts, engine mount bolts, etc.) I'll torque it to spec, but if it's something like the oil filter housing, I don't really care. I work at an oil change shop and we've never had a problem just wrenching it on there good and tight.
Old Dec 5, 2009 | 01:10 PM
slowswap's Avatar
22 in lbs. Says it on the cap.
Old Dec 6, 2009 | 04:50 PM
1niceLS's Avatar
oh well I ll keep that in mind during the install
Old Dec 8, 2009 | 05:39 PM
about 2 foot pounds then.. wow, not much.
Old Dec 9, 2009 | 05:36 PM
kush's Avatar
ah ya, of course it would be exactly where it should be, on the cap. 25 N-M
Old Dec 9, 2009 | 06:35 PM
1niceLS's Avatar
so hand tighten then gently snug with a wrench if need be
Old Dec 9, 2009 | 06:37 PM
D4u2s0t's Avatar
treat it just like the plug in the oil pan... snug, then about a 1/4 turn.
Old Dec 9, 2009 | 06:44 PM
Maven's Avatar
Its 18 ft lbs same for all Cobalt engines.
and yeah, it should be right on the cap if its a GM cap.
Old Dec 9, 2009 | 07:47 PM
jmz250's Avatar
For fucksake don't just hand tighten it. A shop down the road from us blew up an engine that way.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
TedSS
26
Oct 10, 2015 04:30 PM
Builttss
Oct 4, 2015 10:21 AM
Cptnslo
Sep 24, 2015 09:32 AM
