Turning a LT into a SS
Old Aug 4, 2025 | 10:35 PM
Jeeper's Avatar
I have a rusty SS turbo coupe 5 speed and a clean LT coupe auto.
Is a body with the automatic capable of taking the 5 speed?
Old Aug 10, 2025 | 08:35 PM
Dab's Avatar
Dab
It's possible but a lot of work. From my understanding the Auto sits in a different spot, so the motor/tranny mounts and DP needs to be swapped. Also, you'll need to swap the ECU and possibly delete the TCM. The wiring harness & clutch system need to be swapped. You might be better off just trying to find an SS in better shape and harvest all the good stuff from the old one. Or... build a goblin!! :-)
Old Aug 26, 2025 | 08:38 PM
soundjunky's Avatar
they all started out as the same car;
if you have the will to follow through, then yes you can do it...
I am not sure of any components which might have been welded to the unibody which differentiate drivetrains - but that might be a good place to start
Old Aug 27, 2025 | 07:14 AM
Jeeper's Avatar
Thanks for the replies when the shop clears out I am going to try it
Old Jan 25, 2026 | 12:04 PM
erween@'s Avatar
thanks for sharing
Beyonson21
Feb 13, 2018 05:29 PM
Silverbalt92
Apr 25, 2012 05:29 PM
bryce712
Apr 21, 2010 03:18 PM
07cobalt4life
May 11, 2008 06:01 PM
dardi
Feb 23, 2008 04:33 AM
