Vibration while braking...
Old Jun 30, 2011 | 11:06 PM
Pandru's Avatar
My car has been vibrating through the brake pedal, steering wheel, and now the whole car is shaking after braking from 40+mph. My first thoughts were warped brake rotors, so I went and had them turned. I inspected the tie rods and they seemed fine, the wheels wouldn't move when shaking them while car was off the ground. I made sure the caliper bolts were torqued to proper specification as well as the lug nuts and I also went ahead and had a front end alignment done...I'm beginning to run out of ideas, have any of you experienced something similar?
Old Jun 30, 2011 | 11:08 PM
firefighter404's Avatar
front wheels are they balanced, and who turned your rotors maybe your rotor are out of spec
Old Jun 30, 2011 | 11:12 PM
Take2-08LT's Avatar
Your rotors are warped. You can't really turn a warped rotor. Especially the rotors on the base model. Theyre like a feeling pancake. Get new ones and get new pads and tour golden. I know this cause I had the same problem... twice
Old Jun 30, 2011 | 11:14 PM
JaredMeyers's Avatar
i have the same problem with my LS
Old Jun 30, 2011 | 11:17 PM
CleanCut's Avatar
gotta be the discs or pads.. mine warped almost to the point of not being able to be turned... and after i went with ceramic pads... havent had any problems since
AND if you turn your discs, use new pads, dont reuse the ones that were on there before you turned the discs
Old Jun 30, 2011 | 11:18 PM
drumrush's Avatar
same problem, switched to ebc rotors, problem solved.
Old Jun 30, 2011 | 11:27 PM
07cobalt2.2's Avatar
I have the same problem with my g5 gt, my old lt did it to, even with my drilled and slotted rotors suck!
Old Jun 30, 2011 | 11:31 PM
Pandru's Avatar
Thanks for the responses, would you guys recommend I purchase a set of aftermarket rotors and pads versus oem ones? I'd like a little more longevity than 40k miles if possible.
Old Jun 30, 2011 | 11:33 PM
well I have about 15K on my R1 concepts drilled and slotted and mine shake and vibrate, so idk
Old Jul 1, 2011 | 09:33 AM
i want to know what to buy too
Old Jul 1, 2011 | 10:40 AM
Pandru's Avatar
I'm really hoping it's the rotors and not a bent rim, I just got a set of wheels/tires from tire rack a little over a week ago and this problem presented itself after installing them...
Old Jul 1, 2011 | 10:41 AM
Chevycobaltss3's Avatar
I swear bro you have a couple rats in your rim playin cards.. So yeah.. im jk ^^^^^^ this is the issue!!!
Old Jul 1, 2011 | 04:01 PM
CleanCut's Avatar
re balance your wheels, go with stock replacement discs with good ceramic brake pads.. done
Old Jul 1, 2011 | 10:31 PM
jmz250's Avatar
This. Fresh pads and rotors=no shaking.
Old Jul 6, 2011 | 02:04 PM
Chevrolet Cust Svc's Avatar
JaredMeyers and Pandru... did you get your concerns figured out?
Laura
Chevrolet Customer Service
Old Jul 6, 2011 | 02:08 PM
nope i havent been to my dealer yet cuz i live 3 hours away while going to school but im going home tomorrow so i will see if the dealer can fix it. are you really a chevy customer service person
Old Jul 6, 2011 | 02:43 PM
Wtf we have a customer service person? Better not talk abOut tunes! Lol
Old Jul 6, 2011 | 03:06 PM
yea i didnt know there was a customer service person either
Old Jul 6, 2011 | 03:10 PM
OK well just let me know how it goes there - I want to make sure it gets taken care of. And yes if you ever have any questions or concerns just send me a PM and I can look into them for you.
Thanks,
Laura
Old Jul 8, 2011 | 03:31 PM
i am scheduled to get my car worked on august 15th so they should fix the vibration and pull while braking
Old Jul 9, 2011 | 02:18 AM
insylem's Avatar
Only thing I can think of is replacing the front rotors and pads.
Seems like your pretty diligant on your torqueing so no trouble
there.
supajut
Dec 19, 2015 04:06 PM
chefhhr
Oct 26, 2015 10:36 PM
Tupp
Sep 30, 2015 08:18 PM
godsfshrmn
Aug 22, 2006 10:19 AM
