what I need to replace after airbag deployment?
Old Feb 5, 2012 | 10:51 PM
Galadrake's Avatar
Well I'm fixing up a 2007 cobalt ss/sc that was in a front end collision. I purchased an airbag module from a salvage yard, and seatbelts from a different car. What else do I need to replace, and how do i reset the system. Really appreciate any help, thanks
Old Feb 5, 2012 | 10:52 PM
Validater's Avatar
What all deployed?
What damage and where?
Old Feb 6, 2012 | 01:52 PM
Pepsi's Avatar
the part numbers from the airbag module have to match or else it will not work. You change the seat belts, airbags, and module with the battery post disconnected and when you connect it back the light should be off if done correctly. airbag module part numbers MUST match.
Old Feb 6, 2012 | 01:57 PM
advise's Avatar
I've done it b4 when I bought my cobalt totaled
2 airbags 2 seatbelts the air bag computer and the crash sensor
Old Feb 7, 2012 | 10:09 PM
Malaclypse's Avatar
You need to have the SDM (Airbag module) programmed after replacement or it won't work.
You may not be able to use a junkyard module but I'm not positive on that... My thought is, its a safety part so spend the extra cash and buy a new one.
Old Feb 7, 2012 | 11:44 PM
advise's Avatar
not reprogramming needed just get it from the dealer and plug it in i speak from experience
Old Feb 8, 2012 | 08:08 PM
Galadrake's Avatar
How much did it run u from the dealer?
Old Feb 8, 2012 | 08:12 PM
Galadrake's Avatar
also Did you have any problems with radio not working?
Old Feb 8, 2012 | 08:15 PM
advise's Avatar
no problems with the radio i bought it 4 years ago it was around 300
also replace the clock spring might have to do with you radio not working
Old Feb 8, 2012 | 08:47 PM
09xfebalt's Avatar
Alot of Gm cars need the vin learned to the SDM Pretty sure cobalt are the same, if you put used SDM in you may have to program new might just burn vin in by itself upon connecting.
Old Feb 8, 2012 | 08:58 PM
advise's Avatar
yup its just plug and play
more like plug an pray lol
Old Feb 9, 2012 | 01:24 PM
guitarenvy's Avatar
Have to learn the SDM primary key in the BCM after SDM is replaced.
Old Feb 15, 2012 | 01:23 AM
Galadrake's Avatar
Would my steering wheel controls still work if my clock spring was broke? Cuz everything still works ...
Old Feb 15, 2012 | 01:40 AM
Validater's Avatar
The clock spring is recommended to be replaced due to the fact that it is a ribbon cable. and it can melt or such, and as well, sometimes the heat generated by the airbag itself can melt the connectors from the clock spring.
Old Feb 15, 2012 | 02:04 AM
advise's Avatar
x2
Old Feb 15, 2012 | 11:18 AM
Galadrake's Avatar
The clock spring is recommended to be replaced due to the fact that it is a ribbon cable. and it can melt or such, and as well, sometimes the heat generated by the airbag itself can melt the connectors from the clock pring.
Well I know what you guys are saying but I had replaced quite a few in various vehicles and when it breaks or melts u loose all steering wheel controls...
Old Feb 15, 2012 | 04:01 PM
Validater's Avatar
To your question about the radio, check the fuse. I'm sure you already did. Then try pulling it out and check the wires forpower. Acc is only like half a volt or so.
Anyways on to my point, I jump started my car one night, didn't read the owners manual. (If I had I would have noticed it says to turn off the radio first, otherwise it'll blow) long story short that radio died.
agentirons
Oct 16, 2015 02:11 AM
justinchinn
Oct 2, 2015 12:18 PM
Trav3480
Oct 1, 2015 08:17 PM
DANRICKARD
Oct 1, 2015 12:08 AM
importkiller
Sep 30, 2015 07:18 PM
