What other cars came with our F35 transmission?
Old Jul 6, 2007 | 04:29 PM
Onyxd04Redline's Avatar
I imagine a saab but what model?
Old Jul 6, 2007 | 04:52 PM
ironkoijak's Avatar
i am not positive but pretty sure its the saab 9-3, idk what years
Old Jul 6, 2007 | 04:59 PM
RaineMan's Avatar
I dug this up off of a GM website.
2007 Model Year Summary
General Motors Powertrain – Europe F35 five-speed manual car transaxle
● There are no changes for the 2007 Model Year
LOW MAINTENANCE
The MU3 uses a Castrol Burmah (BOT 0063) manual transmission fluid, and is validated as "fill-for-life". No maintenance is required for normal operation.
OVERVIEW
The F35 is a Saab-designed five-speed manual transaxle built in Saab’s Gothenburg, Sweden, powertrain plant. This extensively tested manual transmission was originally introduced in the 1984 Saab 9000, and today it is used in the Saab 9-3 and 9-5, Saturn Ion Red Line, Chevrolet Cobalt SS and on various Opel applications.
The F35 features a two-axis conventional transverse layout, fully synchronized gears, and compact packaging. It features higher torque carrying capacity than many other manual transaxles currently in use in North American small cars.
Different versions of the transaxle are available, depending upon application. Both cable and rod shift mechanisms are available, as well as application-specific clutch housings. The MU3 and MC2 are differentiated by ratios (see specs), with the MC2 available with a lower top-gear ratio.
Design features include triple-cone synchronizers on 1st and 2nd gears, and single-cone synchronizers for 3rd, 4th, 5th and reverse gears.
A limited-slip differential is available for high-output applications. This torque-sensing differential is an all-mechanical geared unit that uses no clutch packs or preloading to transfer torque from one axle to the other, and torque transfer occurs automatically when one wheel loses traction. Torque transfer also occurs gradually, without steps.
Old Jul 6, 2007 | 05:12 PM
Would it be possible to use a final drive ratio out of say the F40 in the F35?
Old Jul 6, 2007 | 05:14 PM
Psykostevo's Avatar
Just upgrade to the ~4.46 final drive out of the Grandam cup cars. It's a GM part that you can buy. Sorry lost the part number when charlie ate my Buildbook.
Old Jul 6, 2007 | 05:16 PM
I don't want to go up.. I want to go down. To a 3.55 in the F40
Old Jul 6, 2007 | 05:26 PM
RaineMan's Avatar
what's the stock final drive?
Old Jul 6, 2007 | 05:29 PM
4.05
Our gearset with the stock 4.05 final drive at 7000rpm :
1st : 37
2nd : 72
3rd : 107
4th : 142
5th : 181
80mph at 3100 in 5th gear
3.55 Final Drive :
1st : 43
2nd : 82
3rd : 122
4th : 162
5th : 206
80mph at 2700 in 5th gear
Old Jul 6, 2007 | 05:35 PM
RaineMan's Avatar
So you'd rather optimize for good cruising over acceleration? Or are you hoping that a lower final drive would decrease wheelhop/spin in 1st?
Old Jul 6, 2007 | 05:38 PM
Psykostevo's Avatar
Then why change final drive, why not just change 1st gear?
Old Jul 6, 2007 | 05:40 PM
RaineMan's Avatar
Hmm... well... I'd look at a Saab 9-3 transmission. They come with a 3.53:1 final drive... right up your alley.
vtecduster's Avatar
Gas mileage on the freeway.
Old Jul 6, 2007 | 05:41 PM
Our gears are too short for the power we are making. 1st gear is seriously useless and going to a longer final ratio would actually make 1st gear useable with street tires.
Because i hate cruising at 80mph over 3000rpm.
Thanks raine. Will look into it
Old May 8, 2018 | 04:32 PM
Todd West's Avatar
What year Saab 9-3 would bolt up to an 04 ecotech??
LOW MAINTENANCE
OVERVIEW
what ye
Old May 8, 2018 | 04:47 PM
Originally Posted by Todd West
what ye
While I enjoy the enthusiasm to figure out what year works for that post, the post was made in 2007, I doubt the user has thought of this page for years.
ashalle2
Sep 16, 2015 10:36 PM
Sean Cummings
Sep 11, 2015 09:35 PM
jcalvin1126
Sep 11, 2015 10:24 AM
Jacque8080
Sep 9, 2015 09:21 PM
soundjunky
Sep 3, 2015 01:18 PM
