What other cars came with our F35 transmission?
I dug this up off of a GM website.
2007 Model Year Summary
General Motors Powertrain – Europe F35 five-speed manual car transaxle
● There are no changes for the 2007 Model Year
LOW MAINTENANCE
The MU3 uses a Castrol Burmah (BOT 0063) manual transmission fluid, and is validated as "fill-for-life". No maintenance is required for normal operation.
OVERVIEW
The F35 is a Saab-designed five-speed manual transaxle built in Saab’s Gothenburg, Sweden, powertrain plant. This extensively tested manual transmission was originally introduced in the 1984 Saab 9000, and today it is used in the Saab 9-3 and 9-5, Saturn Ion Red Line, Chevrolet Cobalt SS and on various Opel applications.
The F35 features a two-axis conventional transverse layout, fully synchronized gears, and compact packaging. It features higher torque carrying capacity than many other manual transaxles currently in use in North American small cars.
Different versions of the transaxle are available, depending upon application. Both cable and rod shift mechanisms are available, as well as application-specific clutch housings. The MU3 and MC2 are differentiated by ratios (see specs), with the MC2 available with a lower top-gear ratio.
Design features include triple-cone synchronizers on 1st and 2nd gears, and single-cone synchronizers for 3rd, 4th, 5th and reverse gears.
A limited-slip differential is available for high-output applications. This torque-sensing differential is an all-mechanical geared unit that uses no clutch packs or preloading to transfer torque from one axle to the other, and torque transfer occurs automatically when one wheel loses traction. Torque transfer also occurs gradually, without steps.
LOW MAINTENANCE
OVERVIEW
Because i hate cruising at 80mph over 3000rpm.
Thanks raine. Will look into it
What year Saab 9-3 would bolt up to an 04 ecotech??
LOW MAINTENANCE
OVERVIEW
LOW MAINTENANCE
OVERVIEW
jcalvin1126
Sep 11, 2015 10:24 AM
