wheel studs
Old Jan 27, 2008 | 03:29 AM
yellowltcoupe22's Avatar
wheel studs
anyone know of some good upgraded wheel studs for the lt four lugs? i've broke two of mine off so far (one on each side of front) and want to replace them all when i replace them two so i dont have to worry bout breakin again..
Old Jan 27, 2008 | 03:49 AM
maverick0716's Avatar
How'd you end up breaking the studs?
Old Jan 27, 2008 | 05:05 AM
im not really sure.. it happened bout a month after i put my 18's on.. i was walkin up to my car and just happen to look down and notice it.. bout a month later one on the other side broke off too.. i guess i may have over tightened em or somethin.. from what i've heard the factory ones are crappy anyways..
Last edited by yellowltcoupe22; Jan 27, 2008 at 05:05 AM. Reason: Automerged Doublepost
Old Jan 27, 2008 | 05:53 AM
If you overtighten any lugnut, it's going to weaken it a significant amount......even if they're aftermarket hardened ones. You should really use a torque wrench to make sure they're all 100 lb./ft......tighter than that and you're just asking for trouble. I've never had any problems with my studs or any other Cobalt/G5 studs, and I work on them all the time. If you want to see really bad studs, look at the GM 2500 trucks.......absolutely terrible for stripping.
Old Jan 27, 2008 | 04:26 PM
yeah i didnt think i had over tightened em though cuz i did it by hand.. but can anyone tell me the stud size so i can order some kinda good harden ones to replace them all?
Old Jan 27, 2008 | 04:31 PM
articzap's Avatar
You have no idea how easy it is to get 100 ft/lbs. You had to have cranked those suckers on there.
Old Jan 27, 2008 | 04:39 PM
yeah i use a torque wrench at work pretty often and usually have to pull at least 300 to 350 lb/ft on most everythin and thats not all that hard to pull so i know i probley did over do it on my lugs a little..
Old Jan 27, 2008 | 06:10 PM
niknyce's Avatar
with my white balt(in sig) used 2 break lugs all the time with my aftermarket wheels. did 5 total in ayear
Old Jan 27, 2008 | 08:06 PM
yeah mine didnt do it till i put my aftermarket wheels on too..
Solaris99
28
Mar 15, 2017 01:22 PM
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
