Whern to switch to synthetic oil
Old Sep 11, 2005 | 11:19 PM
avro206's Avatar
I plan on running my 2.4L SS on synthetic oil. My question is when can I switch?
Redline oils says 1500-2000 miles
Royal Purple says first oil change---so thats probably 3000miles.
Old Sep 11, 2005 | 11:32 PM
Shamrock's Avatar
I watch alot of the "Power Block" on Spike TV, and alot of the shows say Royal Purple is good stuff. They guarantee cooler engine temps with just the oil.
Watched Horsepower TV, and they changed ALL the fluids in the car (including the rearend grease) with Royal Purple products and they gained 4 hp
Old Sep 11, 2005 | 11:43 PM
alleycat58's Avatar
It doesn't come with synthetic from the factory? If not, then just change to what you want to use in it whenever the oil manufacturer suggests.
Old Sep 11, 2005 | 11:49 PM
chevyguy1990's Avatar
you can switch to synthetic motor oil any time you want, synthetic is actually better for your engine.
Old Sep 12, 2005 | 03:43 AM
avro206's Avatar
well out of everything I heard....you cannot change ANY time you want. ON a brand new engine you do have to wait a bit.
Old Sep 12, 2005 | 10:09 AM
05BurntOGSL's Avatar
royal purple is awesome..i run it in my mustang.....cant beat it.......mobil1 is all you need though brotha......
Old Sep 12, 2005 | 10:21 AM
TxCarGuy's Avatar
I changed my oil the first time just over 1000 miles with Mobil Clean 7500 Synthetic Blend 5W-30 and I haven't noticed any harmful results since. I'm now just over 4000 miles and plan on changing again at 5k. Go with what you want and you should be fine.
http://www.mobil1.com/USA-English/Mo...lean_7500.aspx
Old Sep 12, 2005 | 11:40 AM
true, i forgot 'bout that, you can any time after you've broken the new engine in.
Old Sep 12, 2005 | 12:09 PM
CleanNFun's Avatar
My first oil change I put mobil-1 synthetic in (2.2 base model coupe ) and havent had ANY problems..runs great and strong!!! Definetly worth the money...Im not even going to say when you should have your first oil change..itll start a war but whenever you decide to...its a great time to switch
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
717ssbalt
Oct 2, 2015 04:01 PM
importkiller
Sep 30, 2015 07:18 PM
dennis69
Sep 28, 2015 02:16 PM
