Who has CA projectors?
Old Oct 2, 2007 | 09:05 PM
suprchged's Avatar
if so what is the feed back, does it coem with a plug and play harnes like it says??
Old Oct 2, 2007 | 09:07 PM
JPizzle's Avatar
I don't have the CA ones, but basically... it's all plug & play. You just have to hard-wire (tap into the turn-signal wire) for the halos & led's to light up. Or if you wanted them wired up to the foglights, or the headlights, or a switch. What ever.
Old Oct 2, 2007 | 09:10 PM
suprchged's Avatar
ok so the existing bulbs just hook into the new headlights like you were changing a bulb. In a simpler way. What color is turn signal
Old Oct 2, 2007 | 09:13 PM
JPizzle's Avatar
I'm am 99% sure that the CA ones come with the new headlight & high-beam bulbs installed. They are H1's for reference. I heard that the CA ones come with the turn-signal bulb, and the marker bulb. You would only have to reuse the turn-signal bulb and marker bulb from your old headlights, if the CA ones did not come with it.
Old Oct 2, 2007 | 09:14 PM
originaladrian's Avatar
they are super simple to install, dont worry about it and just buy them, (buy the ebay ones, i love to support our vendors but the ebay projectors are the same thing) you wont regret it, the stock lights look like hell.
Old Oct 2, 2007 | 09:38 PM
suprchged's Avatar
And it just the bulbs just plug into the exsisting harness??
TedSS
101
Apr 25, 2016 10:46 PM
Bluelightning
Nov 11, 2015 02:41 PM
chefhhr
Oct 26, 2015 10:36 PM
allpro666
Oct 6, 2015 08:11 PM
juandirtymessican
Oct 27, 2012 10:41 PM
