Interior: Back seat Chirp or Squeak Fix
Old Apr 12, 2008 | 03:45 PM
07cobaltss's Avatar
ALLDATA Online Log Out | Help
Select Vehicle | New TSBs | Technician's Reference
Component Search:
Conversion Calculator
2007 Chevrolet Cobalt L4-2.0L SC
Vehicle Level Technical Service Bulletins Customer Interest Interior - Squeak/Chirp From Rear Seats While Driving
Bulletin No.: 07-08-50-001A
Date: August 28, 2007
TECHNICAL
Subject:
Squeak or Chirp Noise From Rear Split Folding Seat Back or Seat Cushion While Driving (Install Squeak Reduction Tape)
Models:
2005-2008 Chevrolet Cobalt
2005-2006 Pontiac Pursuit (Canada Only)
2007-2008 Pontiac G5
Supercede:
This bulletin is being revised to include the 2008 model year, add a procedure and update the warranty information.
Please discard Corporate Bulletin Number 07-08-50-001 (Section 08 - Body and Accessories).
Condition
Some customers may comment on a squeak or chirp noise coming from the rear seat area while driving.
Cause
The cause of the noise may be the rear split folding seat back pivot pins and the seat cushion retainers contacting the seat brackets.
Correction
Determine and isolate the source of the noise with squeak reduction tape using the steps below.
Test drive the vehicle and verify that the noise is coming from the rear seat area.
Park the vehicle.
Open the trunk.
Pull the two rear release handles located in the center of the trunk.
Tip
Folding the rear seat back assemblies down while road testing will help determine if the seat back pivot pins are causing the noise.
Fold down the right and left rear seat back assemblies.
Tip
Removing the rear seat cushion while road testing will help determine if the retainers are causing the noise. Refer to Rear Seat Cushion Replacement in SI.
Inspect the two rear seat cushion retaining hooks for a witness mark (1). The hooks may be contacting the bracket. Continue to test drive the vehicle.
If the noise is gone, proceed to the next step. If the noise is still present, determine the source of the noise. Refer to Squeaks and Rattles in SI.
Tip
Use of a screwdriver to release the seat back pin from the seat back pivot retaining bracket (1).
Remove the right and left rear split seat back assemblies from the vehicle. Refer to Split Folding Seat Back Replacement in SI.
Cut ten pieces of 3M(TM) Squeak Reduction Tape, P/N 06356, or equivalent, to 10 mm (0.39 in) width by 30 mm (1.18 in) length.
Install four pieces of the tape to the right rear seat back pivot bracket:
The first piece of tape (1) is located at the twelve o'clock position.
The second piece of tape (2) is located at the four o'clock position.
The third piece of tape (3) is located at the six o'clock position.
The fourth piece of tape (4) is located at the nine o'clock position.
Repeat Step 11 for the left rear seat back pivot bracket.
Install two pieces of 3M(TM) Squeak Reduction Tape, P/N 06356, or equivalent around the left and right rear seat cushion retainers (1). Refer to Rear Seat Cushion Replacement in SI.
Install the left and right rear seat back assemblies. Refer to Split Folding Seat Back Replacement in SI.
Install the rear seat cushion back into the vehicle and lock the seat cushion retaining hooks.
Raise the two rear split seats up into position and push back until a click is heard.
Check for proper routing of the rear seat belts. Push and pull forward on the seat backs to verify the seats have locked into place.
Tip
If the seat doesn't lock into place, check the rear seat back striker to the rear seat back latch assembly for proper alignment and adjust.
Verify that the noise has been eliminated.
Parts Information
Warranty Information
For vehicles repaired under warranty, use the table.
Disclaimer
© 2008 ALLDATA LLC. All rights reserved.
Terms of Use
somthing fun i found at class tonight you guys should see the list of TSB's they have out...
Old Apr 12, 2008 | 03:57 PM
MarcS's Avatar
The Stig
approved
Old Apr 12, 2008 | 05:24 PM
07cobaltss's Avatar
thanks! =)
Old Apr 12, 2008 | 05:27 PM
Stouffer's Avatar
Sweet. I didn't want to have to deal with the dealership again. Easy fix
Old Apr 15, 2008 | 01:02 PM
KillinKrullin's Avatar
OMFG THANK YOU. I was about to go to the dealership on friday to bitch. maybe i can hold out and wait till the seats are worn and then warranty new seats... lol most likely not though.
but thank you so much for this. you said there are more.. post up! ty
- Bill
Old Apr 15, 2008 | 01:24 PM
Misery5567's Avatar
I heard this a couple times in my car but haven't heard it since. Nice to know though
Old Apr 15, 2008 | 01:36 PM
fastfreddy7's Avatar
THANK YOU SO MUCH! My car just went 1000 over warranty, and this squeak has been bothering me, now I know what it is and can fix it!! THANK YOU!!!
Old Apr 15, 2008 | 10:29 PM
Ducky22287's Avatar
I got this down at the dealer cause it's under warrenty but great thread, much needed for people without warrenty. I love how they refer to it as anti-sqeack tape at the dealer lol.
Old Aug 12, 2008 | 04:46 PM
Black08SSTC's Avatar
subscribed for a fix on friday, i have the squeak
Old Oct 12, 2008 | 09:47 AM
red06SC's Avatar
Bad. Ass.
I've been looking for that noise for a week now.
Old Mar 19, 2009 | 04:00 PM
PolishPauL's Avatar
I got my dealer to do it and still got the squeak. Did this work for you guys? Any suggestions?
Old Mar 19, 2009 | 04:08 PM
shabodah's Avatar
Just for the Ion guys- Yes, this does apply to our vehicles, too!
Old Mar 23, 2009 | 02:03 AM
2007 ion2's Avatar
WOOHOO!! now they need to fix the front seat and the dash!!
Old May 24, 2009 | 06:23 PM
SSchargedSS's Avatar
THANK YOU
its now fixed! I used 3m cloth anti vibration tape.. i can barely find it anywhere though
Old Jul 14, 2009 | 11:03 AM
Staged07SS's Avatar
Administrator
Administrator
This thread worked wonders for me !!! My car feels brand new again, now that I don't have that annoying backseat chirp/squeak. I used 3M molding tape for my fix, because it is a thicker tape. What an easy and great fix .... Thanks !!!
Old Sep 10, 2009 | 02:45 PM
09turbo's Avatar
sub'd
Old Jan 5, 2010 | 10:01 PM
RYRO14's Avatar
I think I have this rattle, but mine is coming from near the childseat thingys. Is this the rattle they are talking about?
Old Jan 6, 2010 | 12:41 AM
its a squeak / chirp sound, not so much a rattle. those plastic clips for the child seat rattle like hell
Old Jan 6, 2010 | 05:46 PM
RYRO14's Avatar
Mine is like coming from the center speaker cover in the center. Whenever I hit even a small bump it rattles. So I guess itisnt the same one?
Old Nov 19, 2010 | 12:35 PM
07cobaltss's Avatar
man guys, i haven't been on here for awhile... my car is sold and i have a colorado now. Still doing tuning if anyone is interested in my area.
Old Nov 19, 2010 | 08:57 PM
silver_stig's Avatar
Rattle Fix
I had exactly the same rattle you are talking about.
My fix was lifting up the booster seat restraint thingy in the middle behind the headrests.
And my rattling whenever I hit a bump or a deep bass disappeared!
Try that.
Old Dec 2, 2010 | 11:32 PM
CHRISCARGUY's Avatar
sub'd- got a squeek ever since it got cold- might be it.
Old Dec 2, 2010 | 11:47 PM
ecot3c inside's Avatar
this thread is like 2 yrs old, ^^^^ noob.
Old Dec 5, 2010 | 04:41 PM
Yep, and this is the car's 2nd winter. I didn't even have the car when the thread started. If I were a real noob I would have started a new post asking "has anyone heard of this..." and then I would have every basher out there saying, "ever heard of a search?!" Just can't win.
RaginChopsuey
Oct 27, 2015 01:27 PM
Oct 20, 2015 09:56 PM
dieGone
Oct 1, 2015 06:27 PM
Tupp
Sep 30, 2015 08:18 PM
