Cobalt SS Shift Knob Removal, 6 Easy Steps *W/Pics*
Old Sep 8, 2013 | 09:28 PM
Tsbbzm's Avatar
Jedi Master
2006 Cobalt SS factory/stock gear shift knob removal in 6 easy steps, with pics!!!
Hope this helps!
Step#1
Step#2
Use a very small flat tip screwdriver and pry up gently around corners of silver/black cap...remove cap.
Step#3
Use a 25 Torx bit/driver and remove small torx screw from center of gear shift knob.
Step#4
Take two large flat tip screw drivers and place horizontal on each side of shifter knob, and pull upwards. This step helps if you have two people.
Step#5
Once knob is removed, take small spring and foam off of gear shift.
Step#6
Complete!!!
TSBBZM
Old Sep 8, 2013 | 09:35 PM
574's Avatar
574
I'll be using this soon, thanks
Old Sep 9, 2013 | 11:09 AM
Tsbbzm's Avatar
Jedi Master
Glad i can help out
Old Sep 9, 2013 | 11:19 AM
Sox-Fan's Avatar
Got Brakes?
You left out the part about the sledge hammer and 2 sticks of dynamite.
Old Sep 9, 2013 | 08:50 PM
Tsbbzm's Avatar
Jedi Master
Yeah when i researches how to do it thats what everyone was saying.
Little leverage and it popped right off.
The dynamite is being saved for later projects
Old Sep 10, 2013 | 02:30 AM
06cobalt racer's Avatar
nice man! sticky!!
Old Sep 10, 2013 | 07:15 AM
sLAsh's Avatar
What about the part where you pull up with the two screwdrivers and smash it into your forehead when it comes loose
Old Sep 10, 2013 | 07:26 AM
Staged07SS's Avatar
Administrator
Administrator
Moved to How to section.
Old Sep 10, 2013 | 11:38 AM
Tsbbzm's Avatar
Jedi Master
Cant tell you everything
Left the exciting stuff out
Thanks Staged!
Old Sep 10, 2013 | 12:06 PM
06cobaltncng's Avatar
nice! now I just need a new one.
Old Sep 10, 2013 | 12:28 PM
Tsbbzm's Avatar
Jedi Master
Yeah.
I needed to take it off to put on new shift boot.(old one was torn up)
I didnt show it but with these steps done you can basically pull the boot off and whole shifter assembly for that matter
Old Sep 10, 2013 | 05:33 PM
Originally Posted by Tsbbzm
Yeah.
Should have! How does the boot come off?
I want to do a STS and new boot eventually.
Old Sep 10, 2013 | 09:12 PM
Tsbbzm's Avatar
Jedi Master
Boot is connected to a plasic piece than snaps down in there. Just give it a little tug and should pop right out. Once plastic piece is unattached you will notice the boot is connected to it w/ staples. Take staples out and boot comes off.
To get new boot on i used staples just like factory. Took some time but as you can see in pictures it turned out great.
Old Sep 10, 2013 | 10:33 PM
Doesn't sound bad and yes it looks great.
Old Sep 11, 2013 | 07:44 AM
Staged07SS's Avatar
Administrator
Administrator
Just an added note....
You will need heavy duty staples to get through the plastic.
A generic home stapler will not cut it.
Old Sep 11, 2013 | 05:12 PM
Tsbbzm's Avatar
Jedi Master
Correct sir.
I used a staple gun for wood. Much more powerful than home staple gun
Old Sep 11, 2013 | 05:17 PM
tazmanian devil's Avatar
thanks for the info!
Old Sep 11, 2013 | 09:01 PM
Tsbbzm's Avatar
Jedi Master
Welcome!
Turbo Johnny
Feb 21, 2019 09:41 AM
Decepticon06ss/sc
Oct 16, 2015 09:24 PM
How to Guide
57
Oct 15, 2015 11:56 AM
SS_2009_TC
Sep 11, 2015 05:41 PM
SiloGM
Sep 7, 2015 11:04 PM
