General Suspension: FE1 poly cab install
Old Nov 8, 2009 | 10:42 PM
ford sucks's Avatar
are you tired of sloppy handling and wheel hop?
finally hear is our answer!
this is how to install the prothane poly cab's for cars with fe1 suspension.
you will need to get the poly bushings http://www.neverenoughauto.com/index...oduct_id=16743
step 1
remove control arm by removing 1 rear control arm bolt(21mm head)
2 front bolts(15mm head)
and 1 ball joint bolt(15mm nut,16mm bolt).
control arm removed
step 2
remove the rear bushing by pressing it out or you can remove the rubber and carefully cut the metal sleeve and tap it out. i tried both with good results.
remove the front bushing by clamping the metal bar in a vice and hitting the control arm with a large dead blow hammer or equivalent.
control arm with both bushings removed
take the front bushing and remove the rubber from the steel bar.
step 3
if there is any rust where the old bushings were you need to remove it and paint the bare metal.before you install the bushings. remember lube is your friend!
grease both halves of the front bushing and slide them into the control arm. then grease the steel bar that was in the original front bushing and press it in.
now take the rear bushing grease it up and press it in followed by the steel tube lube it up and slide it into the bushing
important there is a small radius on one side of the rear bushing this has to go towards the top of the control arm.
step 4
now that both bushings it is time to install the arm.
you want to grease the bushings anywhere they will touch metal.
control arm installed
front
rear
step 5
repeat on other side
this is how i installed mine i am not responsibly for any damages or injuries.
Old Nov 22, 2009 | 02:27 PM
Black SS/SC 06's Avatar
Approved
Old Jan 7, 2010 | 04:51 AM
stretch89's Avatar
what does this do?
Old Jan 7, 2010 | 04:56 AM
mrsilent13's Avatar
nice upgrade....poly are awesome...nice write up and great idea. thanks for the pics
Old Jan 7, 2010 | 06:42 PM
ford sucks's Avatar
Originally Posted by stretch89
what does this do?
well hopefully they wont go bad as fast as the stock ones. including the originals i have had to replace 3 sets of them . it did help to firm up the feel of the car
Old Jan 16, 2010 | 08:25 AM
constantproject's Avatar
is this a different part number than the fe5 poly stuff. (from a vendor for example)
Old Jan 16, 2010 | 01:08 PM
ford sucks's Avatar
yes the fe5 bushings are bonded to aluminum these arent
Old Jan 16, 2010 | 01:26 PM
Maven's Avatar
theres no metal sleeve on the rear bushing?
Old Jan 16, 2010 | 05:42 PM
ford sucks's Avatar
if i remember corectly wernt the poly cabs for the fe5 arms bonded to aluminum or steel but they would start to seperate.
correct me if i am wrong
Old Jan 16, 2010 | 07:20 PM
thats why i was wondering, because i thought they did too
Old Jan 16, 2010 | 08:06 PM
ford sucks's Avatar
this is what i have always seen for the fe5
Old Apr 3, 2010 | 07:38 PM
ford sucks's Avatar
up date on ordering bushings
prothane dosnt list them anymore only place i can find them for sale is here
http://cgi.ebay.com/ebaymotors/05-Ch...item1c1049e32e
they have a few sets of red and black ones left
Old Apr 3, 2010 | 07:46 PM
if they dont list them anymore they might not make them anymore...damn, because im not in a hurry to spend the 5-600 on fe5s w scabs..lol thanks for the update man
Old Apr 3, 2010 | 07:54 PM
ford sucks's Avatar
i know that is why i up dated it. im waiting for a resonance from prothane about availability of the bushings.
never enough auto on ebay has about 20 sets left but from the looks of things when they are gone there gone for good
just search ebay for 7-777 for red ones or 7-777blk for black
Old Apr 4, 2010 | 12:36 PM
07cobalt_LT's Avatar
thanks for all the assistance, just waiting for mine now
Old Apr 4, 2010 | 12:48 PM
ford sucks's Avatar
its no problem.
i would offer to help install them but you have to come to me
Old May 15, 2010 | 02:00 AM
Brags's Avatar
Nice find. I gotta get these before they are gone.
Old May 16, 2010 | 03:44 PM
Nighthawk243's Avatar
There is a reason they are gone. These type of CAB's don't hold up very well to the stress the Cobalt's design puts them through. They're more failure prone than the stocks are.
Old May 16, 2010 | 03:45 PM
redcobalt07's Avatar
just sayin these are not as simple as they look
Old May 16, 2010 | 09:49 PM
ford sucks's Avatar
not disagreeing because i dont know why they quit selling them but they lasted longer than any of my stock ones did
Old May 16, 2010 | 10:18 PM
ItalianJoe1's Avatar
Spherical bushings in the rear and Delrin/urethane in the front is the only real way to make it work and last. Urethane in that rear bushing just falls apart, can't handle the rotation of the center bushing. Front one it's just a 2-D movement, so it works.
I should see about making a setup for the 2.2 control arms, I did a set for my LSJ and they were awesome.
Old May 17, 2010 | 05:29 PM
Brags's Avatar
You should i know I would buy them Italianjoe
Old May 17, 2010 | 07:47 PM
If there was interest, and someone wanted to supply me with a pair of stock control arms so I can make measurements, it's very doable. I've done it before.
Solaris99
28
Mar 15, 2017 01:22 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
Delta coupe
Sep 30, 2015 08:11 AM
Bohb
Sep 27, 2015 09:11 PM
